wtf my clutch
Posted: Wed Feb 28, 2007 4:59 pm
by Subafury
drove from uni to a shopping centre this arvo bout 15 mins. when i turned the car off clutch felt a little weird ie the pedal grabbed hell closer to the floor. didnt think much of it till i went to go home and it stayed the same all the way home. the clutch has changed its pressure point where it starts to engage- it likes grabs heaps early and then still hasnt engaged until where it normally does. so it left me jerking the car around the rest of the way home.
any ideas what happened? i checked the cable adjuster dont really know what else to check.
Posted: Wed Feb 28, 2007 5:24 pm
by AndrewT
I think Subarino had a similar issue recently and it turned out to be a torn clutch fork....but this got worse slowly over a couple of weeks. Maybe yours has actually partially snapped. Or possibly it might be the actual clutch organic matter giving way, Alex's suddenly went right to the floor aswell when his shredded.
Posted: Wed Feb 28, 2007 7:11 pm
by SuBaRiNo
Yeah... doesn't sound good Matt.... will have to wait and see if u lose the entire clutch operation... or if u slowly lose adjustment and need to keep adjusting it.
At this stage it sorta does sound like u have done something to the clutch fork... but if u have then this should start getting worse very shortly.
Any idea how old the clutch is?
Dave
Posted: Wed Feb 28, 2007 7:26 pm
by Subafury
no idea how old. and damn i was just thinkin wouldnt it be funny if my clutch had gone this month too- recently along with alex, subarnio and d dave.
now looks like it has grrrrr.
Posted: Thu Mar 01, 2007 9:44 am
by BrennyV
Lol, these last few months seems to be clutch month! Everyone’s killing them!
Posted: Thu Mar 01, 2007 11:21 am
by daveosubi
Mines finally getting replaced today, it was scraping the rivets on one side and obviousally slipping alot.
What brand is it thats bending forks? A friends installing it for us and just said it's a slightly heavier duty clutch and cost $240, Ill be able check the brand tonight when it gets put in.
Posted: Thu Mar 01, 2007 6:40 pm
by Subafury
after driving on it today it shudders alot engaging into 1st and 2nd, a little bit better into the higher gears prolly coz im moving but still not as easy to let the clutch out. i think it may also be a little slippage in it so yesh not very nice to drive at all. so looks like im up for a new clutch- even if its just the fork might as well replace the whole thing while im down there.
so would people recommend the beefed up clutch and flywheel from that custom place? or should i go with the HD exedy one from work or just the standard one?
Posted: Thu Mar 01, 2007 10:53 pm
by SuBaRiNo
I wouldn't beef it for your motor... go the HD one. It will increase your chances of fork problems if u get the hardcore clutch.
Dave
Posted: Sun Mar 04, 2007 12:50 pm
by Subafury
hmmm my clutch feels alot better for some reason, not like it did when i posted this thread. i had a bit of a fiddle with the cable adjuster too and now it seems almost normal. maybe im going crazy but yeh looks like its all running smooth again. i figure ill do something about it if the clutch or fork breaks altogether and im left with no drive.
thanks for the advice anyway.
matt
Posted: Mon Mar 05, 2007 10:16 am
by SubiDave
My clutch just did the same thing last week, monday it was very hard to change and then I had to have the pedal down so hard it dented the carpet, ow I have no clutch at all, died a very quick death it seems.
Posted: Mon Mar 05, 2007 5:32 pm
by BlackMale
Sorry for the hijack... Dave are you saying that you clutch is gone again?
Posted: Mon Mar 05, 2007 6:21 pm
by SuBaRiNo
Which Dave??
Dave
Posted: Tue Mar 06, 2007 7:59 am
by BlackMale
SuBaRiNo wrote:Which Dave??Dave
yer sorry i miss read... i am up to speed now (should no read the board all wired up hey)
Posted: Sat Apr 14, 2007 8:29 pm
by Subafury
crap. looks like its done it again. as soon as i got my car back together again- replaced cv (this one is shagged too), replaced diff- went for a test drive and the clutch is gone all weird again as per my original post.
about a week after that post tho it came good again hopefully it'll happen again. only thing this time there is a scraping noise and clutch is much harder to press.
looks like the subi will have to make its first trip to the mechanic (since i got her) to get it sussed.
Posted: Sun Apr 15, 2007 1:43 pm
by vidler
clutch fork?
Posted: Sun Apr 15, 2007 6:39 pm
by SuBaRiNo
A clutch fork problem wouldn't just solve itself and come good for a few weeks like it has seam to.
Dave
Posted: Sun Apr 15, 2007 7:28 pm
by Subafury
well it didnt exactly come good, still felt slightly weird- i had more shuddering when using the clutch. ill get it checked out
Posted: Sun Apr 22, 2007 7:01 pm
by Subafury
i got the mechanic to have a quick look over it/drive. he reckons the slight shuddering is a warped flywheel, but could be more. so what im gonna do is order a new clutch kit and when that comes in ill crack the gearbox apart and change the bits. should solve the problem. will keep ya posted.
Posted: Mon Apr 23, 2007 7:31 pm
by AndrewT
Let me know if you need another flywheel, I should have a few here. Otherwise perhaps get yours skimmed.
Posted: Mon Apr 23, 2007 7:38 pm
by midlifecrisis
I had the same thing a few months ago in my L sedan, Turned out that the cable was just about to break, So I replaced it and all is good with the world again.
Marc
