ea82T head ?
- stamp_licker
ea82T head ?
pulled the heads off to see if the head gasket blown after many other tests failed to locate why the overflow bottle kept pressurising.can't see any leaks but the drivers side gasket has silver stuff all over the gasket both sides and the block and head also,can't tell what brand of gasket.the passenger side looks nice and clean the gasket is a monotorque.is the silver stuff normally there or is this a indication of chemi weld?what else should i be looking for in the head area before reassembly?still can't see why the overflow would be pressurrising
Building a hardcore postie:D
So the silver stuff is on the gasket & head/block?
Sounds like the head gasket had blown then. They separate & leave the silver bits on the head/block & then form pin hole leaks.
Just buy a VRS kit. I can get you a price.
http://www.subiparts.com.au
0438 887 746
0438 887 746
- Suby Wan Kenobi
- stamp_licker
- steve_rising_sun
