window help!!
- suba_dooba
window help!!
just recently i wound my window down and for some reason its stuck all the way down and wont wind back up. the winder is jammed or something. ive taken all the panelling off the door but i cant really find anything i can do to it.
window for subaru L series and is the drivers side door
cheers
cheers
1991 Subaru L series enduro wagon--3" lift, kings, gabriels front with kybs back (no longer kybs back due to strut plates breaking at wedge), cb, .... Future mods are a pipedream at the moment due to money issues.
I really should start thinking of making a picture for my sig
Electric or manual window winder??
Dave
Dave
yer sounds like u need a new window regulator (guessing u got manual windows to)
but the splines arent all worn out on the window winder are they?? and does it turn at all with a bit of force or nething
but if u got power windows then it culd be the same thing or it culd be that the switches have worn out and not contacting
maybe take some pics and post em up but if u can see the winder with wire all hanging around and evrything liek that then its msot likely screwed
(bring it to my work to fix it
Wagon is no longer....
- suba_dooba
there not electric. its the manual winder and that is jammed or something. the splines are all good
- suba_dooba
get a new one
they are usually held in by like 3 nuts or somthing on the frames running inside the doors behind the panels.
it attaches one side where the window winder will stick on and the other around the glass area i think they kinda look like a slanted item running up the door with some wire in them for when ur winding
Not sure if this will help but I have a set of touring wagon doors...they are rusty so you wouldn't want them whole. But you might want the window mechanisms - full electric ones in good working condition.
Either that or maybe the part that has failed in your door is common between both electric windows and manual, might be able to just swap that over.
Anyways these doors are sitting in my shed and going cheap!
