EA-81/82T Thermostat replacement option.
l had the opportunity today to rummage through Repco's parts shelves looking for a thermostat and have come up with a replacement that opens at 160 deg to replace the standard 180 deg unit.
This thermostat is made for a Holden but is 54mm diameter, (same as early Subaru). The hole for this is central and not offset as is standard but with an early turbo this is not an issue as water enters the motor from the top, not the side as with standard motors.
Details for this Thermostat are,
Brand, Dayco.
Part no. DT14C-BP
Opens, 160 degree.
Brand, Dayco.
Part no. DT14C-BP
Opens, 160 degree.
Redskin
89 Brumby
EA-81T.
89 Brumby
EA-81T.
- discopotato03
Triden already make a 77c opening offset valve thermostat for Subaru EA82's - at least they did for mine !
I was going to run a Datsun 200B Triden 77 thermostat till I found out they do one to suit . My 86 RX Turbo runs fine (well virtually same) as the jamed open thermostat did only it warms up faster and sits at a fairly constant temp now .
I think the story is with these old cars is if in ANY doubt when you buy it replace the radiator and thermostat as soon as practical . Because the value of most of these cars is low a cooked engine = a dead car so I think to give it a fighting chance put a bit of effort into the cooling system .
Reliability is everything , cheers A .
i installed a tridon hi-flow thermostat on my ea82t yesterday and tested it 4x4ing. works well. i couldnt really see a difference in diameter between that and a normal one tho but it was only a few bucks more so i thought why not.
also it says that it is blistered too. what does this mean?
part no is TT2041-185 fyi
- subalex
I've just done the same change in my EA82 engine. It works fine. Really, it's just a matter of the diameter being right. The two thermostats otherwise do look a lot different. I even took a photo if this question ever arose but it works exactly as it should. The thing barely rises a few millimetres from the cold line when at normal operating temp now and only goes higher when worked hard.
'91 Sportswagon - 3" lifted, 14" speedys, 27" Nankangs + lots of small details improved. Wouldn't mind some extra grunt from an EJ.
