Bent Tie,radius rod and stabiliser bar
Milla
Post by Milla » Tue Sep 11, 2007 10:05 pm
Big problems with the front right of the car.
Lookin from the ride side of the car the front tyre sit approx 2" closer to the rear of the car than it should.
Upon inspection i think the radius rod and stabilser bar are bent. the radius on about a 120 degree angle pulling the car towards the righthand side of the road.
Q's
Can i just take out the radius rod and bend it back into shape or do i need a new control arm and rod and the rest of the kit.
If so how much would this kind of set up cost approx at a wreckers.
P.S if anyone can help this wkend i would be most greatful as i am suppose to drive up to exmouth on the 22nd ( at least a carton)
New Ride: 1990 L touring Wagon, 2"Lift, Rear Wheel Carrier, Cargo Barrier, Roof Bucket, Replacment Bullbar, Spotties, 27" BFGs
EJ20t sti
01 Sti running gear.
Want :Dual range forester box to suit
Rip:93 L 2 1/4" exhaust, 14" sunraysias, cargo barrier, 32/36weber, king springs, KYB's, 3" lift , 27" rubba. 15" superlites.
Post by Alex » Tue Sep 11, 2007 10:17 pm
hahaa...whatd ya hit?
best thing is to put new ones in. Not sure about prices but shouldnt be tooo much.
90brumby
Post by 90brumby » Tue Sep 11, 2007 10:23 pm
Alex wrote:hahaa...whatd ya hit?
when u say new 1s u mean second hand 1s
ye not too hard or tooo expensive a few people carry spares just 4 that reason
(i wish i carryed a spare)
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
SuBaRiNo
Post by SuBaRiNo » Tue Sep 11, 2007 10:24 pm
Have u been to the pines??? LOL
Best bet would be to get 2nd hand replacement parts... although some of the old school guys may remember Jaffa doing the same thing in his L on the power lines track. He straightened his on the day on the side of the track and is still running it in his car. So it can be done but i wouldn't recomend it.
Dave
Matatak
Post by Matatak » Tue Sep 11, 2007 10:24 pm
hmmm they dont jsut bend for no reason so did u hit something??
i not sure on Lseries but if its bent the radius rods it wuld have most likely bent the control arm to so rebending the rod back into shape may fix that but ull still have a bent control arm.
best thing to do wuld be go and source out some nice straight ones from Wreckers and install them both at same time.
shuldnt be to hard and sum1 might even lend u a hand
wt suburb u in?
definitely wuldnt pay over $50 at wreckers (maybe thats way to high aswell :???:)
edit - wts a stabiliser bar ?????
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AndrewT » Wed Sep 12, 2007 12:57 am
yeah just get some secondhand replacements, should be less than 50 bucks. Have a look in the quokka for people wrecking L series. Very quick to remove and replace these.
Stabiliser bar I think maybe referring to the front sway bar.
Milla
Post by Milla » Wed Sep 12, 2007 1:15 am
stabilser/sway same thing i think too just goin off the gregory's book. i dont think the control arm is bent, mainly the radius rod.. bent like this..... <.......
can i just take the rod off and replace or is it an assembly thing. coz takin the whole right control arm and rods and bars off could be a task.
PS. im in bentley, just behind curtain on the manning road side.
EJ20t sti
Post by AndrewT » Wed Sep 12, 2007 1:19 am
yeah you can take the radius rod off by itself. 3 nuts hold it on....one up near firewall, into the radius rod bracket. and two under the control arm.
The two nuts under the control arm can be difficult to remove. I'd recommend using a breaker bar and a hex socket for this as they can round easily otherwise. They will likely be very tight if they havn't been removed in a long time.
Milla
Post by Milla » Wed Sep 12, 2007 1:24 am
gives me a good reason to buy some more tools then, cheers for that andrew...and the rest of ya's. will give feedback!
BTW: had a small accident with a roundabout and my race driver ego at about 80km/h, damn wet roads. some call me shooooomacher u no!!
EJ20t sti
daza
Post by daza » Wed Sep 12, 2007 10:09 am
If the radius rod is clearly bent then the control arm will be twisted slightly, not a prob but expect it to be fiddly to get the straight radius rod in...
Most of us have been there at some stage :rolleyes:
Daza
:D
Post by Alex » Wed Sep 12, 2007 2:55 pm
ive done it :D....Milla, make sure your captive nuts are still ok. Otherwise youll get made pay like i just have been! :D
showthread.php?t=4885
SuBaRiNo
Post by SuBaRiNo » Wed Sep 12, 2007 9:14 pm
It's an MY... captive nuts should be fine.
Dave
Matatak
Post by Matatak » Wed Sep 12, 2007 9:19 pm
SuBaRiNo wrote:It's an MY... captive nuts should be fine.
Dave
what tha
how u readin that??
im thinkin the car in hsi sig is the one hes doin the fixing on and thats an Lseries
lol :p
SuBaRiNo
Post by SuBaRiNo » Wed Sep 12, 2007 9:23 pm
Ohh ok.. my bad... in that case yeah you might want to check em... lol
Dave
90brumby
Post by 90brumby » Wed Sep 12, 2007 9:52 pm
does it have a lift kit fitted if not i doubt very much that he would have damaged them
Milla
Post by Milla » Thu Sep 13, 2007 6:07 pm
no lift, will check tho
EJ20t sti
Post by Subafury » Thu Sep 13, 2007 9:48 pm
id lend ya i hand but havin some problems of my own atm. possibly sunday tho if ya havent done it by then
Milla
Post by Milla » Sat Sep 15, 2007 7:49 pm
can do it fine, just stripped the 2nd nut down near the wheel end of things. gonna drill the F***** out and get a new bolt n nut.
cheers anyhow.
EJ20t sti
Post by AndrewT » Sat Sep 15, 2007 8:09 pm
yerp I told u those were toughies =) did ya use a hex socket?
Milla
Post by Milla » Sat Sep 15, 2007 9:26 pm
hex socket and breaker bar, musta jus been really tight. dont got no tool that can fit in the hole to get out a rounded nut, so drillin is the go
EJ20t sti
