check engine light on 98 outback
- dirty skirt
the check engine light is coming on when when the engine is cold and stays on 4 a bit then goes out im guessing its got something to do with the temp sensor but what i want to know is can i get the code out by bridging wires at the connection where you put the hand held computer plug?if so what pins are they a diagram would be nice if someone has got one and list of what the numbers are to what code it is
thanks heaps guys i know someone will be able to help me
steve
steve
Is your Outback running the standard ECU? You say you have a hand controller so I'm guessing it's some kind of aftermarket ECU then??
If it is the standard one then there should be two black connectors near where the ECU is. If you connect them together then turn the ignition on, the check engine light should start flashing.
Count the number of long flashes (example - 3), and the number of short flashes (example - 4). This would be a code of 34. (I think I've got short and long round the right way!).
Theres a listing on the forum somewhere of what each code means - search is your friend.
Frog did the post for the codes
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
- Suby Wan Kenobi
- dirty skirt
- dirty skirt
code 21 is the Coolant Temperature Sensor.
wont affect to much with the running of the car. but may or may not be telling the ECU the engine is always cold and slightly increasing the fuel consumption.
(id like someone to confirm if it does aswell coz ive been wondering if it will infact do that when theyre disconnected.)
Wagon is no longer....
- dirty skirt
- Suby Wan Kenobi
- FROG
Diagnostic Trouble Codes - 1992
Subaru
11 Crank Angle Sensor (No Reference Pulse).
12 Ignition Switch.
13 Cam Angle Sensor.
14 Injector 1.
15 Injector 2.
16 Injector 3.
17 Injector 4.
21 Engine Coolant Temperature Sensor.
22 Knock Sensor.
23 Air Flow Sensor.
24 Air Control Valve.
31 Throttle Sensor.
32 O2 Sensor.
33 Vehicle Speed Sensor.
35 Canister Purge Control Solenoid.
41 Air / Fuel Learning Control Function.
42 Idle Switch.
45 Atmospheric Pressure Sensor.
49 Air Flow Sensor.
51 Inhibitor Switch (A/T).
51 Neutral Switch (M/T).
52 Parking Switch (A/T).
Subaru
12 Ignition Switch.
14 Injector 1.
15 Injector 2.
16 Injector 3.
17 Injector 4.
22 Knock Sensor.
23 Air Flow Sensor.
31 Throttle Sensor.
32 O2 Sensor.
42 Idle Switch.
49 Air Flow Sensor.
