L series sucking tooo much fuel
Posted: Thu Apr 17, 2008 7:46 pm
by rcs66
My 93 L series wagon (EA82) 200,000km is using way to much fuel. I was wondering what I should do before I take the carb off and rebuild it.
I am only getting about 270km a tank. I change the oil and plugs about every 5000km and the air filter is new. The butterfly opens when the car warms up.
Does this cat have a cataltic converter ?
Who in Sydney can anyone recomend that does older subies ?
Lastly and this might sound a bit dumb. But what is the black canister at the
front right hand side of the engine bay, with hoses going up under the carb ?
CHeers.
Posted: Thu Apr 17, 2008 10:42 pm
by Gannon
270km a tank, that aint good. Has it been doing this for long?
Are your tyre pressures correct? does the exhaust gas smell fuely?
Most importantly,... what is you driving style? If you drive like Michael Shumaker, dont expect to get good economy.
Yes it has a catalytic converter
The black canister is called the purge canister. It basically takes fuel vapour from the fuel tank while the car is parked in the hot sun ect. and stores it until you next start the car. Its an emissions device. I doubt this will be causing economy issues.
Posted: Fri Apr 18, 2008 7:43 am
by AlpineRaven
rcs66 wrote:My 93 L series wagon (EA82) 200,000km is using way to much fuel. I was wondering what I should do before I take the carb off and rebuild it.
CHeers.
Sounds like the carby needs a good Tune up.
All Unleaded cars are suppose to have Cat. Converter.
Posted: Fri Apr 18, 2008 8:46 am
by theclick
just another thing, actually do a fuel consumption calculation. It appears that my fuel tank goes in only 280km, but the dial must be wrong because i get 11l/100, and a "fill" only puts in 39l
Posted: Fri Apr 18, 2008 8:53 am
by fredsub
timing belt stretch or off a tooth or 2 causes high fuel consumption like that also. You didn't say how well it drives? like a pig or go go?
Posted: Fri Apr 18, 2008 9:30 am
fredsub wrote:timing belt stretch or off a tooth or 2 causes high fuel consumption like that also. You didn't say how well it drives? like a pig or go go?
If it was a tooth out you'd know about it... like trying to get a brick moving.
Get the car up to temp and idle it, pop bonnet and have a look a the carbie. There's a plunger style pump on there that can leak fuel out the top (where the plunger shaft comes out). Its a common problem with the hitachi carbies. A rebuild kit will sort it out.
Also, how much is a fuel tank? 20L? 100L? I filled up last night from half a tank, 32L, 300km, half of that around town heavy footed driving. How do you drive it, where do you drive it and how many k's to amount of L's put in the tank?
Other than that, check out your aircleaner, replace if dirty. This problem could be a series of things adding up to your fuel consumption problem.
Posted: Fri Apr 18, 2008 10:01 am
by daveosubi
theclick wrote:just another thing, actually do a fuel consumption calculation. It appears that my fuel tank goes in only 280km, but the dial must be wrong because i get 11l/100, and a "fill" only puts in 39l
Good point I get 135km more km's from when my gauge hit's the empty mark, It also doesnt hit the full mark, get's to about 3/4 full on the gauge
Posted: Fri Apr 18, 2008 10:54 am
by booma
Hi,
I have also had the same issues with my 92 L series Hitachi carby.Fuel leaking,crap economy,smells.
Fuel was leaking from around the plunger port,took it to the local carby refurbisher who did what other posters are suggesting rebuilt it with a complete rebuild kit.
That fixed that problem.
BUT I have the same problem regards to fuel capacity,I cannot get more than 30-35 litre in the tank.I did take the tank fuel sensor out and clean it once.
WARNING !!!! If you do this disconnect the battery first and pref in a well ventilated area with no naked flames,best to do it with a near empty tank. We don't want to see you on the 6 o'clock news !
Suspect there is a blocked breather pipe that I have missed somewhere.
Ideas anyone ?
Posted: Fri Apr 18, 2008 1:13 pm
by Busdriver
If you do take the fuel sender out and try to clean it or adjust,be very careful because I found that a little change to the needle makes a huge difference at the fuel gauge. When I got my car, it only showed half full when full, so i bent the arm that runs up and down the wire coil on the sender (only tiny bit) and then my gauge read full when full, but would not drop to emty when empty,so another try resulted in a gauge that read empty when full and slowly climbed to 3/4 as the fuel was used!
