l series box leaking
R1173
Post by R1173 » Mon Nov 17, 2008 8:41 pm
The duel-range 'box is leaking. Is this common? How do I fix it? How much?
Post by Subafury » Mon Nov 17, 2008 10:36 pm
depends. id say pretty expensive to pull apart and fix. check you havent overfilled it, and obviously the nut is tight. mine leaks a little weeny bit, i think its just the way they are
Post by AndrewT » Mon Nov 17, 2008 10:37 pm
First thing is to identify exactly where it's coming from. If it's from around the shifter linkages I have heard this is not a major job.
