spike wrote:honestly WTF. efi carbi?? its single point injection, just go a efi from ea82 i think
supercharger-turbo?? yes its done really expensive and very little room to move under bonnet.
put it this way lots of money, lots of engineering.
and english??
don't get pissy, well not unless you have all the know how..... which you may have some of but not all.
efi from a 82 is mpfi (seprate intake port for each cylinder) - 81 heads only have a single intake port for both cylinders on each side.
for starters the intake wouldnt bolt up.
82 heads wont bolt onto a 81 because of were the cam/cams/push rods/belts are on both engines.
depending how hands on you are and how legal you want it to be, it wouldnt cost the earth to build.
if i was you i'd either do something like the plane builders- ea81 with a 82t turbo or something around the same spec, carby draw through style. i think some seals within the turbo need swaping out if its a wanted to be reliable with petrol getting suck through it.
or a small toyota supercharger slapped on there.
but at the end of the day it wont be a super car, it will how ever be a lot of fun building and driving. just be carefull of who you line up at the lights to avoid embarassment.
google ea81,turbo and light plane and see what it turns up.
