hey all
just wondering if people know if a mechanic (transmission joint) can fix a noisy gearbox? thrust bearing / clutch been replaced but you can hear the gearbox inside the car which i was advised by the 2nd previous owner... dont care if the gearbox could be on its way but just want the noise to stop.. anyone know if a mechanic is able to do it? without actually buying another gearbox which is hard to get?? cause i need a front wheel drive gearbox as my '92 liberty is front wheel drive
Gearbox Issues
Thrust Bearing is at the front of the gearbox, you need to remove the gearbox to access.. - Do that at the same time with clutch job.
Gearbox can be noisy due age & kms... Change the oil and see if it does make difference. Mine is noisy with normal oil, but with redline oil, and I would strongly recommend Redline shockproof and its money worth, got 5 litres for $120.
