R160 diff preload?
H-top
R160 diff preload?
Post by H-top » Wed Dec 15, 2010 9:30 am
G'day,
can anyone tell me the preload for setting up a
r160 rear diff?
H-Top
rolling in
Post by TOONGA » Wed Dec 15, 2010 10:00 am
I have the manual transmission and differential section for the EA81 series it has the diff specifications if thats any help.
http://rapidshare.com/files/436984125/C ... ential.pdf
not sure if thats the r160 specs you are after but it is a start
H-top
Post by H-top » Wed Dec 15, 2010 10:03 am
Would that be applicable to a ej r160?
H-Top
rolling in
Post by TOONGA » Wed Dec 15, 2010 10:08 am
if it is one of the series 1 gen1 or gen 2 with the male stubs AFAIK it is the same differential.
if Im incorrect it will become apparent :) when someone else posts differently
Post by AlpineRaven » Wed Dec 15, 2010 1:17 pm
Gen 1 - correct.
Gen 2 has female stubs hence CV joints needs to be male-male ends.
What specific information are you after H-Top?
vincentvega
Post by vincentvega » Wed Dec 15, 2010 6:25 pm
he was pretty specific
"can anyone tell me the preload for setting up a
r160 rear diff?"
H-top
Post by H-top » Wed Dec 15, 2010 7:22 pm
my bad vincentega.
following toonga, i used my Vortex WSM
H-Top
rolling in
ScubyRoo
Post by ScubyRoo » Fri Dec 17, 2010 12:47 pm
If you send me a pm with your email address I'll send you an excell sheet and the page from a '92 factory liberty manual on calculating preload and shim requirements.
Owen.
