EJ22 engine manual same as auto?
MidcoastScooby
Post by MidcoastScooby » Fri Mar 04, 2011 12:40 am
Hi, haven't been on this forum since my son rolled the L-Series last year. I now have a new project.
Can the EJ22 motor be swapped from an auto car to a manual car? All I want to do is swap motors over, anything I need to change or check on? Is it easier to drop the motor or lift it out?
Thanks in advance.
Post by RSR 555 » Fri Mar 04, 2011 12:50 am
You can use a EJ22 mbehind either manual or auto.. the engine are the same, you'll just need to swap over the obvious things like flywheel/clutch but everything else is the same :)
Engine will need to be lifted out as the crossmember is in the way of dropping it out the bottom
Post by AlpineRaven » Fri Mar 04, 2011 6:20 am
People have different opinion about taking out engines. For me due equipment I have I find easier to pull engine out with gearbox attached from top while cross member still attached to the chassis with Radiator removed first.
MidcoastScooby
Post by MidcoastScooby » Sun Mar 06, 2011 9:10 am
Thanks guys.
FROG
Post by FROG » Sun Mar 06, 2011 9:35 am
I think the starter motors are different from auto and manual ..... I think ....
Depth of throwout ???
Post by TOONGA » Sun Mar 06, 2011 11:49 am
Frog the depth of the throw out is a little different but the main difference is the size of the mounting hole the starter motor sits in. the automatic starter has a bigger mounting hole and the flange hole on the gearbox is bigger than for the manual starter on the manual gear box.
FROG
Post by FROG » Sun Mar 06, 2011 1:16 pm
Ah yep , alarm bells were ringing ;-)
vincentvega
Post by vincentvega » Mon Mar 07, 2011 9:15 am
starter bolts to the gearbox so that really doesnt matter.
one thing that is different is there is a guide on the timing belt in the manuals to stop the timing belt skipping a tooth. its not fitted on the autos. This wont be a showstopper though. plenty of people have converted to manual without worrying about this.
