Where is transaxle oil filler
revmax
Post by revmax » Wed Oct 12, 2011 6:39 pm
for my 00 Auto outback.
Found the drain plug but where the heck is the filler hole.
Please anyone !
Post by TOONGA » Wed Oct 12, 2011 7:00 pm
you will have one on either side of the auto transmission on the drivers side (right) is the transaxle oil (short stick honey coloured oil) on the passenger side (left) is the transmission oil (long stick red coloured oil).
Don't mix the two as catastrophic failure can be the result.
sorry forgot to add the oil goes in via the dipstick tube
revmax
Post by revmax » Wed Oct 12, 2011 7:16 pm
Thanks Toonga. I couldn't see it cause a massive wiring loom was in the road.
Phew now I will be able to do an oil change.
mattl200
Post by mattl200 » Wed Oct 12, 2011 7:48 pm
if your changing the tranie fluid dont forget the filter under the left hand guard liner bout $15 from burson or the like
Post by NachaLuva » Wed Oct 12, 2011 9:12 pm
Only slightly off topic, wheres the dipstick for a '98 forester gearbox...if it has one. I'v looked & looked but buggered if i can see it!
Post by TOONGA » Wed Oct 12, 2011 11:14 pm
same spot as the auto box on the right side of the engine
taza
Post by taza » Wed Oct 12, 2011 11:17 pm
nachaluva wrote:Only slightly off topic, wheres the dipstick for a '98 forester gearbox...if it has one. I'v looked & looked but buggered if i can see it!
I had the same issue. Remove the part of your air filter box the same way as you remove your air filter, then look straight down and you will be able to see it. I couldn't find mine at first because the yellow dipstick was covered in grease :rolleyes:
Taza
revmax
Post by revmax » Thu Oct 13, 2011 4:50 am
mattl200 wrote:if your changing the tranie fluid dont forget the filter under the left hand guard liner bout $15 from burson or the like
Thanks Matt. Yer done that not long after I bought it.
