if you have EA82T heads for sale can you just send me a hello PM, in preparation for engine pull down very soon. If I find cracked head I am sure to have a panic on, am pretty sure I want to drive EA82T at this stage rather than the big conversion, because then I'm sure I wanna put EA82T heads on normal block for higher compression with lpg conversion in mind and reduced turbo lag.
thanks, Jonno
EA82T heads maybe wanted in near future...
It's not that uncommon to find cracks between the valves in the EA82T heads. I've heard plenty of stories of people re-using the heads if the cracks don't extend very deep into the head, although from what it sounds like you're planning to do to the motor it might be better to have a good set of heads. Having said that finding un-cracked EA82T heads may not be that easy. Been there done that after I discovered mine were cracked almost right down to the valve guides.
