AWD without a Centre Diff
Have you ever heard of a torque limiter (the thing found on PTO driven farm equipment to protect your tractors gearbox when you hit a stump)
They also use them in manufacturing www.ringspann.de/uk/products/p45/p45rs.htm
What if you were add one of these between the gearbox and the rear diff.
You would have engine power to all 4 wheels, but it would slip (but still maintains preset torque) under high strain and enable your car to corner without binding up the gearbox.
The ones designed for slashers are about 6" in diameter and have 8-10 springs that allow the pressure/torque threshold to be adjusted
Just a crazy idea i had
What do you think
What do you think
- Captain Obvious
hmmmm could work kinda like a viscous diff in a lib box me thinks
That is just a rather agricultural (pun intended) LSD isnt it?
EZ30 L series - Monsterwagon
- Brumby Boy
What do you think
Dont we live on crazy ideas around here???
RIP 1992 Brumby
RIP 1992 Brumby
I agree with Mattims. Also how you going to bind it up so it dose not release for 4WD? or are you just talking about on road use only.
Yeah i was thinking on road use only.
My thoughts originated from the viscous coupling in the early AWD auto forester and liberty gearboxes. I read somewhere that the front wheels are connected permamently to the engine, and there is a proportion sent to the rear axle, controlled by the viscous coupling.
Or something along those lines.
I thought about it binding and releasing with a clunk, but i read this on a website...
Are there any other ways of achieving what i wanna achieve? What do other AWD systems use?
Lets make this a brain storming session!!!
So i figured that it shouldnt be all that bad (clutch LSD's work in a similar way)During the slipping process, input and output rotate relative to each other and the preset limit torque continues to be transmitted.
Hey Gannon, Just dug up this while doing a search.
Sorry to see the discussion didn't go any further - did you actually look any further into it? I'm guessing not
I reckon the easiest way to test it would be on a part time 4wd gearbox, locking in 4wd with the PTO's torque limiter hanging out the back of the gearbox...
Yeah my fab skills weren't all that good at that stage, but my idea was to attach it to the centre bearing carrier between the gearbox and the diff.El_Freddo wrote: I reckon the easiest way to test it would be on a part time 4wd gearbox, locking in 4wd with the PTO's torque limiter hanging out the back of the gearbox...
good idea. would it withstand 6000rpm/200kmh or 3000/100kmh
Most PTO driven equipment is designed for 540rpm, but some machines also run on 1000rpm. Id say if it was balanced properly, it would be ok
- vincentvega
- discopotato03
Corect and thats why it wouldn't work . They are designed to be an overload protection device and they would not take kindly to constant slipage .
And erm no , the gearbox drives the center diffs hemisphere which drives the cross pins and then the planet gears on these pins drive the side gears . One side gear is effectively the front diff pinion and the other turns the riser or "transfer" gears to the rear output and tailshaft . The load is balanced driving in a straight line or around corners till a wheel slips . Then the power (torque) goes out the path to the most lightly loaded wheel ie the slipping/spinning one . The viscous hub is just there to limit how fast one side gear can turn compared to the other side one . Being really road cars these need to be quiet and unobtrusive which also limits their effectiveness as an off road traction aid . If they had a serious middle LSD they do clank and do bind and thats part of the compromise .
For an all out competition tarmac car the 4 Matic system is best because it gives the best trade off of RWD characteristics with all paw traction . Its the system Nissan used in the original GTRs though in race trim they flicked all the G sensor electronic control gear .
What they do is have fixed RWD as in an inline engine and gearbox . The back of the gearbox has a transfer case with a multiplate wet clutch a la motorbike and a front output shaft connected to a front diff housed in the side of an aluminium engine sump . They use hydraulic pressure to vary the load from free to direct drive , smartys use the power steering pump as the pressure/fluid provider . In the road cars the wheel speed sensors detect slip and the ECU signals the wet clutch to progressively power the front diff .
The system doesn't wind up because when the wet clutch lets go all the drive is from the rear diff .
The race cars had what looked like a hydraulic handbrake with 5 or 6 steps ie from free to direct front diff drive , aside from launching the drivers set it to taste and left it alone . No way Nissan could do this with road cars so they have all the problematic electronic crap . They still had to build understeer into the roadies because Joe average wood duck always kills himself in cars designed to oversteer or understeer less anyway ...
There is no ultimate system other than long travel coil suspension attached to 6WD and four lockable diffs . In other words buy a 6WD Pinzgauer .
http://www.4x4road.com/tipspinz.htmldiscopotato03 wrote: There is no ultimate system other than long travel coil suspension attached to 6WD and four lockable diffs . In other words buy a 6WD Pinzgauer.
Oh yeah baby
Make those stupid Landcruisers look lame lol
thinking about all this traction is fine, but i do not accept the old saying
i think a rear locker would be better, then lock the center up
we can lock the front and rear but until we start going mad with lift and flex. While offroading (rock hopping) isnt really my scene i know that this system doesnt do it all.who needs articulation if you've got lockers
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
You do realise this thread is 5 years old?
yeah ahaha wondered why it got opened up again
GETDIRTYCLOTHING
GETDIRTYCLOTHING
My faultspike wrote:yeah ahaha wondered why it got opened up again
Interesting discussion though, I reckon it'd work - if you've ever used one of these on farm machinery they cop a beating! Longevity wouldn't be an issue, the issue would be the rotational speed.
Gannon, don't take people's comments personally - they're not out to attack you, even if it seems like they are. Some of the best idea came from something crazy!
sorry gannon wasnt aiming anything at you just throwing my ball into the roomEl_Freddo wrote: Gannon, don't take people's comments personally - they're not out to attack you, even if it seems like they are. Some of the best idea came from something crazy!
the idea would work, but the revs and duration would be the problem
and the work in hooking it up and having to replace it would be outragous
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- discopotato03
I think the issue with Subarus is suspension travel , even if you could lock every diff can you keep enough feet on the ground to keep moving .
Don't think 6WDs with diff locks can't have every wheel turning at the same speed without actually moving . A bit exciting when it weights 24 tonnes and trying to drag it up steep rock shelves !
I think the most unstopable one I ever drove was an army prototype Leyland Mastiff 6WD . Big wide 18Rx22.5 super singles tyres and real good suspension travel .
