Ea81 very loud ticking
I replaced head gaskets on my brumby and since then i have had an awful ticking, its even youder then the exhaust!
The valve clearences are spot on, hot and cold.
I have done the test for piston slap and its not that, i replaced pushrods but still didnt fix it.
Its odd how it happened since the gaskets were done and the noise is deffinaly in the head end of motor.
Anyone had this problem or know a solution?
- thunder039
Does your EA81 have black or green rocker covers? If they are black it means you have hydraulic lifters and if you set the clearances to solid lifter model, then you're going to have a very noisy engine
never seen an EA81 with hydraulic lifters.
- Silverbullet
I thought only Jap market 81's had hydraulic lifters? Even then not all of them did; my EA81S had solid lifters.
ajbuwalda, if you plan on swapping the lifters over good luck, that's a split engine block job![Smile :)](./images/smilies/icon_smile.gif)
![Image](http://i963.photobucket.com/albums/ae112/Jefferies991/sig_zpsazh7rvic.jpg)
That is just Paul spreading rumours ...my Subie parts guy with nearly 30 years experience says the AUDM did not get hydraulic liftered EA81, and if they did, hydraulic lifters would be listed and available....the black rocker covered jobbies did have some nasty sharp tin bits on top of the adjusters to stop you mucking around with settings (coz they are hydraulic?
who nose?) My 92 sometimes sounds like a hydraulic is mucking up - black rocker covers Aus delivered, original engine on 495,000 ....
Paul is gonna tear an AUSDM EA81 down just to prove he is correct, my parts guy will just have to swallow video evidence![Smile :)](./images/smilies/icon_smile.gif)
![Very Happy :D](./images/smilies/icon_biggrin.gif)
- Brumby Kid
EA81 is defianantly solid, and to change is defianantly a split block job.
After a full rebuild like mine, if te noise was there what would you do?
- Silverbullet
That's a knurled pattern. I wish I could remember if they are important or not but I think mine were all facing outwards.ajbuwalda wrote: Also i noticed some machined checker handgrip looking things like the handle of a rachet on one side of the pushrods, are they ment to face a certain way or doesnt really matter?
- brockharro
How long did you run it for,
I have a EA81 with black rocker covers and hydraulic lifters.
I had a big ticking noise after doing the head gaskets, all it was was air in the lifters, Noise disapeared after 15-20 mins.
You have to be very careful not to get any junk down the pushrod bores.
Try setting the tappets so there is no clearance.
[SIGPIC][/SIGPIC]88 Subaru Brumby (Currently being restored.
84 brumby 2 inch Lift(very rough, Big tires)
Landrover series two. 186 holden banger under hood.
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Hydraulic lifters... fun fun. My sisters L series took 3000km for them ALL to settle in! Admittedly looking back on it the oil pump seals were probably sucking air - the car had to complete a drive from central vic to Port Douglas which is roughly where it all went quiet as it should have been. This was an EA82 though.
Re-check the clearances and set for the hydraulic lifters (if there's a different setting) then give it a week.
Have you changed your oil type since doing the head gaskets?
My memory is sh*t to put it nicely but I know that some EA81 motors DO come with hydraulic lifters, I have some (thanks Jono) kept nicely away for the next engine build. Now getting back to my memory, I recall the little sticker (gold in colour I think) on top of the black rocker cover stating that the valve adjustment was not required as they preset to the correct tension.
Another thing to check is, is the oil getting up to the rockers? as the headgaskets can be on back to front. Did you check the oil feed ring on the gasket was in the correct place on the block?
