imprezza fuel pump
lickabout
imprezza fuel pump
Post by lickabout » Thu Aug 23, 2012 2:23 pm
Hi, my 2004 imprezza 2 litre fuel pump is howling its head off, and ive had a look at where its located to renew it. The outlet (pressure hose) from the pump has an unusual looking fitting on it with 2 brown spring loaded plastic tabs (1 on each side) Is it simply a matter of squeezing these tabs to unclip the line, or is a special tool required. Yes I know i have to de-pressurise it first. Thanks
d_generate
Post by d_generate » Fri Aug 24, 2012 6:09 pm
Not sure on the fittings on an 04 but it should un-clip near the in tank housing, I'd suggest replacing it with a Walbro 342, just make sure it's genuine, they usually go for around $120 on Fleabay.
http://www.ebay.com.au/itm/SUBARU-WRX-W ... 2c6722c83d
Also go look at the back of your car, only 1 z in ImpreZa.
Post by RSR 555 » Sat Aug 25, 2012 9:32 pm
Yes, just push the line in and squeeze the 2 tabs, then pull the line out. No special tools required.
