Brumby 4WD problems
- Dean.nabbe
Brumby 4WD problems
i had the back of my Brumby Jacked up and on stands to fit my lift kit.. i put it in low range 4WD and 1st gear to try lock the back wheels so i could remove them.. but the back wheels would still turn freely..
i thought being in 4WD would stop them turning... or am i wrong?
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
- Dean.nabbe
i thought, even with both wheels off the ground, the wheel turns the diff, turns the drive shaft, turns the gearbox, turns the front wheels and engine.. front wheels are on the ground and handbrake is on, so using that chain of events, the back wheels shouldn't turn.
i'm not very mechanical, so hence the question..
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
Doug is correct, you have an open rear diff.
The handbrake works on the front wheels.
You have 2 diffs in your standard Brumby, front and rear.
As these are not limited slip, if one wheel looses traction on a differential, it will be spun freely by the motor, as it is the easiest to spin.
4wd means you need to lift 2 wheels, one front and one rear to spin wheels.
If you put it in 4wd lift one rear wheel off, all other wheels on the ground, it will not spin.
In 4wd you really have changed it from 1 wd to 2wd.
Add an LSD or locker to get 3wd or 4wd.
Spin one back wheel with both the back wheels off the ground, the other will spin in the opposite direction and the tailshaft will not turn.
Look up how differentials work and it may make it clearer.
L serious, still.
Handbrake works on front wheels not back ( which you probably already know)Dean.nabbe wrote:i thought, even with both wheels off the ground, the wheel turns the diff, turns the drive shaft, turns the gearbox, turns the front wheels and engine.. front wheels are on the ground and handbrake is on, so using that chain of events, the back wheels shouldn't turn.
So I'm thinking -
1) run car in FWD , put on handbrake and lock front wheels , rear will still rotate freely until car stops.
2) Run car in 4WD, put on handbrake and lock front wheels, rear wheels will still rotate with power.
I believe that the diffs enable all wheels to turn at different rates, and that the rate for 1 or more wheels can still be zero, with the engine continuing to turn.
So yes the rears ( I think) will still turn - and perhaps turn your engine over if you are in 4WD as well .
- Dean.nabbe
ah ok.. i think i understand now... whilst it is technically in 4WD it is actually in 2 diff drive..tambox wrote:In 4wd you really have changed it from 1 wd to 2wd.
2WD = Front diff
4WD = both diffs
each wheel on each diff will still work independently from it's counterpart.
unless you have diff locks of course
1987 Brumby.
still to come:
2"exhaust
winch bar
1987 Brumby.
still to come:
2"exhaust
winch bar
- Dean.nabbe
Rear LSD is the most viable for normal driving.
Welded diffs are good for 4wdriving in stuff where you are going to need it, but thats all, its a pain the rest of the time.
Lockers are rare, I have seen Detroit ones, they are great for hard 4wdriving.
Some LSD make 4wdriving much more enjoyable![Cool :cool:](./images/smilies/icon_cool.gif)
The front diff is harder, you need more power first.
L serious, still.
- Dean.nabbe
Any R160 diff with stub axels from any Subaru will fit fine.
Just make sure it's the correct ratio to match your gearbox.
The Viscus LSDs are quite common and pretty cheap - found in early Liberty RS.
Clutch LSDs are very rare - found in early L series RX turbos.
EZ30 L series - Monsterwagon
