subaru royale 89 model
outback_98
Post by outback_98 » Sat May 20, 2017 4:11 pm
after the headgaket torque settings on the EA 82 motor,its a leone royale 89 model,anyhelp be greatly appreciated.Thanks
Post by El_Freddo » Sat May 20, 2017 6:29 pm
The torque settings should be printed on the label with the new head gaskets. Usually done in three steps. They will usually show you the bolt torque sequence too.
Anyway, the Haynes manual lists the torque settings as:
Step one: 29Nm
Step two: 59Nm
Step three: 64Nm
I hope this helps you out.
When setting the cam shafts, remember to line one up, then rotate the crank 360 degrees. Then fit the second belt the usual way ;)
outback_98
Post by outback_98 » Sun May 21, 2017 9:09 pm
ok so had bit trouble with timing belt but mechanic friend came helped with that,engine all back in etc etc but now it wont crank,checked everyhing we can think of,any ideas ?
Post by El_Freddo » Sun May 21, 2017 10:47 pm
Won't crank or won't fire up?
If it's not cranking, double check the wire to the starter solenoid is actually on properly. These can slide between the female connector and the plastic clip, resultin in a poor connection. Or it's not connected at all.
If it's not firing, make sure the plug to the dizzy is connected. It can hide really well sometimes. Also check the wiring/connections at the coil.
Let us know how you go and we'll see what else can be thought of with a little more info ;)
outback_98
Post by outback_98 » Mon May 22, 2017 9:07 pm
yeah have checked all of those things and replaced coil plug with new one,double checked every thing every wire etc.So i dunno :/
Post by El_Freddo » Sun May 28, 2017 9:51 am
All sorted now?
outback_98
Post by outback_98 » Sat Jun 10, 2017 1:37 pm
nope,have now replaced the timing belts and had a mechanic look at it still not going,would anyone have a link to something to make sure we have the timing right?
Post by El_Freddo » Sat Jun 10, 2017 4:43 pm
Are you lining up the three timing marks on the flywheel or the TDC?
You need to find three little lines off to one side of the timing marks, use these to reference for crank alignment.
Fit one belt (passengers side from memory), rotate crank 360* the. Fit the other belt.
If you don't have these three marks as the setting for the alignment it won't run. Good news is the ea82 is a non interference engine so no damage other than the mechanic's pride :p
outback_98
Post by outback_98 » Sun Jun 11, 2017 9:36 am
rotate to the right?
Post by El_Freddo » Sun Jun 11, 2017 11:16 am
Yep clockwise. It really doesn't matter unless your tensioner isn't working properly...
outback_98
Post by outback_98 » Sun Jun 11, 2017 2:08 pm
ok done and tried again still nothing im bloody lost as to what its problem is ive had subarus for a very long time ranging from vortexs to impreza outback forester and this leone but its got me stuffed.
outback_98
Post by outback_98 » Sun Jun 11, 2017 2:39 pm
Post by El_Freddo » Sun Jun 11, 2017 4:17 pm
A few things:
- was the dizzy removed from the cam box and re-aligned correctly?
- have you confirmed that you've got spark?
- got fuel coming in?
- was the dizzy dropped or knocked? This can result in needing a replacement ignition module inside the dizzy.
- have you got the firing order on the leads sorted correctly?
- is the coil wired up properly??
Got some pics you can share?
outback_98
Post by outback_98 » Sun Jun 11, 2017 5:41 pm
yes to all except to pics as its not at home,its going on a trip to a different mechanic in the morning :/
