EA81 or EA82
soobs_rule_m8
EA81 or EA82
Post by soobs_rule_m8 » Wed Sep 20, 2006 10:33 pm
I recently put another EA82 in my bus. I have heard some guys rekon the EA81 was a better motor. I was told less oil leaks, less rattles and more power. Any thoughts??
Don't want to upgrade to anything bigger - rather put something in it that will bolt straight in.
I thought the EA81 was from the older models but was also told they were in the last of the brumby's. Did they come out for unleaded???
Any ideas appreciated
91 L series wagon 4wd. standard stuff like mags, tint, cent lock. import donk. No pics.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Sep 20, 2006 10:40 pm
The 82s had more power than the 81s about 10kw i think as long as the seals are good in the 82 it wont leak and make sure if you are rebuilding the 82 that you service the oil pump if not replace it they arent expensive
The long road ahead
soobs_rule_m8
Post by soobs_rule_m8 » Wed Sep 20, 2006 10:45 pm
I was thinking of getting another motor to rebuild in my spare time. Any idea of prices on seals/gaskets or overhaul kits for either motor?? I'm assuming the 82 would be more with the timing arangement.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Sep 21, 2006 12:42 am
The timing belts are about $30 a pair and a gasket kit around $250 with everything
The long road ahead
smoov
Post by smoov » Thu Sep 21, 2006 12:50 am
EA81 or EA82
EJ ;)
if you're considering the bother of converting to an EA81 engine into your EA82 car, then why not consider an EJ conversion?
food for thought.
1998 Subaru Legacy GTB
Post by steptoe » Thu Sep 21, 2006 10:42 am
resale value ? seeing a tin rocker cover in an L ?
all EA81's made for unleaded coz alloy heads needed hardened seats
