removing rear axle?
removing rear axle?
trying to remove the rear drivers side axle for the first time, and it does not want to come off. is there a trick to getting it off easier. i will grind down the diff stubb once i get the axle off. Any tips would be great. thanks
paul
paul
88 L series Sports Wagon, Weber 32/36 carby, 2" Lift Kit, King Springs all round, 14" Desert Rats, 27" Super Trippers, Welded Rear Diff, Dark tint, JVC Mp3 Deck.
I usually undo the diff hanger and let it flop to one side.
EZ30 L series - Monsterwagon
- Suby Wan Kenobi
- Suby Wan Kenobi
If you have decent heading head on your oxy it will only need a gentle tap tp get it off. I have seen some very stubborn ones too. YOu could always try and get the ones from the wheel end off and then remove the whole diff assembly and do it out of the car, it may seem like more work but it is easier swinging a big hammer out in the open as opposed to under a car. make sure you then use never sieze when re assembling so next time it all comes out easy.
The long road ahead
The long road ahead
