Dual Port Head Rockers
Are Dual Port Head Rockers different? As the push rod on number 3-4 (piston) ton the exhaust side don't line up. Ie the push rod hits the head?
Thanks
Matty
Thanks
Matty
"Claudia"
"Claudia"
Shouldnt be
Dual port heads arent much different to the normal ones, only that there is a divider in the exhaust port
The intake is different too, much better flow. I post up pics later but you can easily see the valves through where the intake mainfold bolts up.
"Claudia"
"Claudia"
The Valves are swaped to standard EA81... They are the same arrangement to the EA82.Suparoo wrote:Shouldnt be
Sorry matt, never compared mine with standard..
- discopotato03
Will post up pics later tonite, if i get a chance.
Thanks for the replies.
"Claudia"
"Claudia"
In that case i withdraw my previous statement.Phizinza wrote:The Valves are swaped to standard EA81... They are the same arrangement to the EA82.
We learn something every day:D
