engines out
FROG
quick parts prices
Post by FROG » Thu Jan 10, 2008 2:13 pm
Head Gaskets 68
In Man Gskts 14
Vc Gaskets 42
Water Pipe O 12
Cam O Ring 7
Cam Seals 24
Crank Seal 12
Water Pump Hose 17
Rear Main Seal 32
Oil Strainer Seal 15
Block O Rings 15
Engine Mount 100
Ring Set Non Gen 120
Vss 80
Thermo & Gskt 26
Pistons And Heads
Checked And
Cleaned Vss Fitted 220
Clutch Reused 20 000klm
Cam Belt Refit 20 000 Klm
more to come prices very rough without gst
cheers
Andy
madmat
Post by madmat » Sun Jan 13, 2008 9:08 pm
Hey Frog: Where are you getting most of your parts from? other than Head Gaskets which i will get genuine i'm looking to rebuild my ej25 this week. It all went bad this arvo as the Chemi Weld finally gave up and i had to be towed home. This will be my second set of head gaskets.
Thanks Mad Mat
FROG
Post by FROG » Mon Jan 14, 2008 3:58 pm
I GET EM FROM ME.... I WORK AT A SUBIE DEALER :-) PM ME YOUR VIN IF YA WANT ANYTHING
OR [email protected]
FROG
block
Post by FROG » Sat Jan 19, 2008 9:46 am
just got the call from my engine builder :D my block is ready yay
went 020 thou oversize got new pistons and rings (hastings?) cost me $400 for the o'size pistons and $200 to bore block vss got fitted for free
so now a shameless plug for Paul at PTS auto and aero engineering here in Griffith for all his help and advice TOP BLOKE
got a lot of work left to get it all back together :rolleyes:
cant wait to find some mud :twisted: :twisted: :twisted:
note to all high milage ej22 owners -- wiring harness under intake manifold had rubbed thru the split tubing and had NEARLY rubbed through to the wires on the underside -- just something to be aware of
cheers
Andy
madmat
Post by madmat » Sat Jan 19, 2008 9:54 am
mate with all this rain we HAVE MUD LOL LOL.
just about to start fitting my motor in this morning. should be running by this arvo.
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
FROG
Post by FROG » Sat Jan 19, 2008 10:04 am
Bragger
My Mechanic And I Both Have Monster Hangovers This Mornin And Hes Not Keen At All Lol
Yep Its Hissing Down Here Too I Cant Wait Maaate
madmat
Post by madmat » Sat Jan 19, 2008 6:24 pm
I might have been bragging this am but not so happy now see my post this arvo.
FROG
done!!!
Post by FROG » Fri Jan 25, 2008 2:30 pm
Shes all back in and running took her out for a test drive last night :-D
there is a noticable power improovement (as i had hoped) :cool:
still got a little hla tick should have that sorted this weekend :rolleyes: SORTED YAY
but overall im very happy :D
blew the budget big time as i wasnt expecting the block to be rotted out
basically i scrounged a second hand block had it bored out .020"
splashed out on oversize pistons and rings and the usual gaskets and o rings, heads were cleaned and skimmed with new valve stem seals fitted
i gapped the rings myself :D boring job but well worth the effort i took advice from Paul at PTS auto and aero engineering
he gave me specs that will suit my off road driving (extra thou clearance in the bores and a couple extra on the ring gap)
sorry but couldnt do the pics thing as my camera died and all my coin is now sitting in my engine bay
from the time i got all the parts in the workshop it took two of us 14 hours to rebuild it together with an awfull lot of alcohol :twisted:
ive disconnected my heater core as i dont trust it (used to gargle under the dash) made a steel u bend to rejoin
ive kinda lost track of the cost but i seem to be a couple of grand at least lighter than i was before :rolleyes:
BIG THANKS TO ALL THOSE WHO DID OFFER ADVICE AND HELPED OUT JUST FOR THE SHEER FUN OF IT
CHEERS GUYS
one very happy frog
"ribbet ribbet"
now then wheres the rain ?
