92 L Series Auto Problem - HELP!!!!
I have an 92 L-Series 4WD 3-speed Auto.
Today the auto gave up.
I can select P and the auto locks, anything else is like being in N.
I have checked the fluid level (just above full - fluid pink and clean)
I have checked the linkages between the shifter and the trans (all seems OK - I assume this is working as I can select P).
Any suggestions on what I can do to figure out what is wrong??
cheers,
Richard
cheers,
Richard
when ur in drive can you hear any grinding or noises?
Hunter S. Thompson
Hunter S. Thompson
I had a similar problem in a '89 skyline, it turned out to be that the torque converter crapped itself. I cant remember how much it cost but was less than getting another gearbox.
Im not sure how it was tested but I think the mechanic had to take it out to see, I guess you could check the transmission pan for any broken metal, which could indicated weather it's gearbox or torque converter.
Quite possibly the torque converter then.
sounds like it.
try in drive with some rev's get some one to look via your inspecion hole in your bellhousing. i have seen the flex plates sheer on those boxes
Hunter S. Thompson
Hunter S. Thompson
Perfect excuse for a 5sp manual conversion
- stamp_licker
- Bratgeebah
auto
Hi
I have an auto that has only done 36000 km since new. It has been sitting under the bench since the late 80's early 90's when my gear box builder pulled it from an L series he bought brand new. I got it from him 12 months ago and never used it and sadly wrote off my L wagon last week. I am in Melbourne.
Gee 0407 348 391
Gee 0407 348 391
- Bratgeebah
- INEEDABEER
- Bratgeebah
