EA82 Head reapair
suby87
EA82 Head reapair
Post by suby87 » Mon Jan 07, 2008 3:40 pm
Hey Guys does anyone know where in Melb I can the heads off my L series repaired as the one quote that I have got is $750 for the both to be welded and reconditioned. Anyone got any ideas?
Post by El_Freddo » Mon Jan 07, 2008 6:13 pm
Hey Kris,
Cracked heads i'm guessing? Prob best bet is to strip down an engine at pick a part and take a good set of heads from them, get them pressure tested and shaved if needed... This would most likely cost less than half the price of that quote for both heads.
I got my heads shaved and tested for $60 each.
PS other option is to check out places in regional "cities", they may be out of town a little bit but most likely won't have the same demand for attention as the city shops... might be worth a try ;)
Post by AlpineRaven » Mon Jan 07, 2008 6:23 pm
If they were cracked, go to wreckers and find another set of un-cracked heads and get them machined they can be around $45 upwards each. Better than paying $750 for it!!!!
Post by steptoe » Mon Jan 07, 2008 7:51 pm
all head services 1300 41 61 81 did mine, cracks etc for near half that, in Melb you lucky person
colwyn
Post by colwyn » Thu Jan 24, 2008 12:47 pm
What about a ea82T head they would be harder to find 2nd hand i'd imagine, i'm told the rx turbos are prone to head cracks after a while and I have a 2nd rx off the road which most certainly has a cracked head but was quoted up to 2k to fix it.
Any advice on a cheaper solution or cheap parts!
Post by steptoe » Thu Jan 24, 2008 10:01 pm
all head, try them yet. When i dealt with them they had normal efi heads that they drilled and tapped to suit turbo.
cwinter
Post by cwinter » Thu Jan 24, 2008 10:16 pm
Where are they cracked?
suby87
Post by suby87 » Fri Jan 25, 2008 7:10 am
Hey they are cracked between the valves in the center all four heads that I have hear but that seems to be the only place. Its not much concern now it I got a 89 fuel injected L series for $500 which is a one owner female it whole life 211000Ks just needs some minor maintaince. That was a lot cheaper than geting the head repaired and now I have fuel injection.
cheers
r00fi
Post by r00fi » Thu May 22, 2008 5:08 pm
FYI
Current Price
$463 pair c/o + gst
12m/20k warranty
Part Number SUBEA82TWPT
timmo
Post by timmo » Thu May 22, 2008 8:50 pm
what exactly is this price for?
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Post by Gannon » Thu May 22, 2008 9:13 pm
With EA82 heads...
If they are cracked between the valve seats, its generally not a problem. The majority of the time the cracks are only superficial.
If they are cracked through to the waterjacket and leak coolant, replace the heads, they will only cause you trouble
r00fi
Post by r00fi » Thu May 22, 2008 10:45 pm
Pair of EA82T heads with valves. Change over
peter richardson
Post by peter richardson » Tue Jun 03, 2008 12:49 pm
i have a gl subaru that is feul injected with twin exhaust port heads so i have been told are stuffed they a cracked between the valves and am looking for two new heads and god they are so hard to find am at the moment looking at a replacemnt motor any one got some advice please need help or a solution
peter richardson
Post by peter richardson » Tue Jun 03, 2008 12:51 pm
apparently the cracks are quite deep and have been told not worth repairing
Post by El_Freddo » Tue Jun 03, 2008 1:26 pm
peter richardson wrote:i have a gl subaru that is feul injected with twin exhaust port heads so i have been told are stuffed they a cracked between the valves and am looking for two new heads and god they are so hard to find am at the moment looking at a replacemnt motor any one got some advice please need help or a solution
Never heard of the twin exhaust ports, you sure you're not meaning twin inlet ports? These are found on any MPFI or MPFI trubo motors. There's little difference between them, just don't use the turbo cams if you pick them up too.
peter richardson
Post by peter richardson » Tue Jun 03, 2008 9:28 pm
does that mean a wrx engine will fit in i am pulling the valves out tomorrow to see how bad the cracks are hopefully only superficial
Post by El_Freddo » Wed Jun 04, 2008 12:11 am
peter richardson wrote:does that mean a wrx engine will fit in i am pulling the valves out tomorrow to see how bad the cracks are hopefully only superficial
Check out the Thread in the Engine, gearbox and diff section or the Conversions section. It will be a "sticky" and titled something like "fitting an EJ to an older MY or L series subaru". That'll have plenty of info there, including me dreaming about a turbo in my L. Should answer some q's and get a few more raised.
Basically the short answer is yes, a WRX engine will fit in an L with some work.
