thrust bearing not engaged, suggestions
Post by D3V1L » Thu May 07, 2009 10:56 pm
yeh hurry up im waiting!!
have u got the bypass codes for the brant?
if its just a code issue get the reset codes and at least u wont have to rip it all out
dave
vidler
Post by vidler » Thu May 07, 2009 11:01 pm
yeah got the master and the user code but neither seem to do anything... there is a box under the dash that has a battery in it that i've heard can go flat when left for ages, so that could be the problem. will be investigating on saturday
09 Forester XT Touring Wagon
Post by D3V1L » Thu May 07, 2009 11:39 pm
aaah yeh i forgot about the battery backup thing
Outback bloke
Post by Outback bloke » Fri May 08, 2009 1:45 am
Sounds like some thing wrong with the clutch set up. If it is all bled and working properly it will only take two full pumps for the slave to push from right in to working. Maybe you had some air in there still?
vidler
Post by vidler » Fri May 08, 2009 8:37 am
hope not... that mean taking the intercooler off again:) definitely bled it through till i got the new oil and no bubbles... feels normal now, have to wait and see if it shifts okay
Post by AndrewT » Fri May 08, 2009 9:15 am
When you say oil.....you mean brake/clutch fluid right?
FROG
Post by FROG » Fri May 08, 2009 9:16 am
vidler wrote:
ready to fire up now apart from issues with the crappy brant alarm system....
got it cranking over but no fuel is getting through, guessing the alarm system imobilises the fuel pump or something... just going to rip the brant out
there is an updated keypad module available that may help you just need to know which brant you have
vidler
Post by vidler » Fri May 08, 2009 6:34 pm
AndrewT wrote:When you say oil.....you mean brake/clutch fluid right?
yes...
just about to start hunting for the brandt manual now
Post by AndrewT » Fri May 08, 2009 11:53 pm
lol that's good, thought it might have been the problem! :)
U should get Subarino to come hotwire it for the purposes of test driving...
