jzk25 wrote:We need to confirm some facts here before people get the wrong ideas into there heads and waste there time/money.
I am not an electronics expert but I am a Subaru expert
. I have also dealt with all types of subaru autos as well as swapping transfers between boxes and monitoring the solenoid activity with the select monitor.
Al I am an electronics expert, and i have a fair clue about subarus aswell (obviously nowhere near your experience though). I am sorry mate but you have got this one wrong.
If you have a solenoid failure on a non turbo car without VTD you are left with fwd only, this would equate to having 0v to the solenoid.
I have a 91 NA liberty auto. Non VTD. Using an oscilloscope, I have observed the TCU controlling the solenoid whilst driving my car, and also a Gen1 turbo auto and the output is the same:
0V at the dutyC solenoid LOCKS the clutch packs. 4WD
12V at the dutyC solenoid OPENS the clutch packs. FWD
I can guarantee this 100%. I have modified both of the above cars with a switch for locked 4WD, and a switch for FWD. The sand flying out the back of the car when im in the dunes is a pretty good indicator that i am NOT in FWD! And the front wheel burnouts i can do when i flick my FWD switch are also a pretty good indicator im in FWD!
I have never had to replace a dead dutyC solenoid but if a dead solenoid does infact equate to 0V at the solenoid as you say, then a dead solenoid will result in locked 4WD. The only thing i have seen result in FWD is burnt out center clutch packs. I have seen this happen 3 times (boosted motor + idiot driver + 3000RPM stally...)
If you have a solenoid failure on a turbo car with VTD you are left with a locked driveline, this would also equate to having 0v at the solenoid.
So applying 12v to a VTD car removes the rear drive bias.
I have had no experience doing this but steve has - and he seems to think that 0V at teh solenoid does not result in locking the driveline.
Applying 12v to a normal transfer gives a locked driveline.
This is incorrect.
The thing with a VTD transfer is it has a centre differential as well so it is still awd without the clutch pack operating but it is like an open diff, the drive will go to the pinion with the least traction.
An open center diff AWD is fine for onroad. We are not talking high performance road cars here, they are all lifted monsters with chunky tyres that dont handle real well anyway. Your still going to have tons more traction than a FWD car.
