Swaping engine mounts
PeeJay
Post by PeeJay » Sun Jan 08, 2006 12:49 pm
What is the easiest way to change an engine mount on an EJ without removing the engine?
legacytt
Engine mount Change
Post by legacytt » Sun Jan 08, 2006 2:42 pm
Unbolt both mounts from the crossmember, lift of jack up the motor enough for them to clear before unbolting the broken one from the block. Reverse to replace. You will have a small amount of movement ,more if you undo the rear engine support rod.
PeeJay
Post by PeeJay » Sun Jan 08, 2006 3:02 pm
Ahh, doesn't sound so hard! Thanks.
