L Wagon short shift kit?
bretgc
Post by bretgc » Wed Oct 22, 2008 8:13 pm
hey guys, is it possible to get a short shifter on an L? or is it something that has to be custom made?
Thanx
Bret
Matatak
Post by Matatak » Wed Oct 22, 2008 8:57 pm
if you can cut and weld im sure you could make your own.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
bretgc
Post by bretgc » Wed Oct 22, 2008 9:04 pm
cutting paper poses problems for me...:p
Post by AndrewT » Wed Oct 22, 2008 9:23 pm
I highly doubt there was a short shifter manufactured for L series. Maybe for RX turbo which should bolt in but even if there was this would be incredibly rare these days. It would be easy to just pay a welding guy like 20 bucks to do it for you and modify your existing linkages.
bretgc
Post by bretgc » Wed Oct 22, 2008 9:26 pm
sounds like a deal. cheers fellas :D
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Oct 23, 2008 11:27 pm
You only need to move the pivot point up about 15-20mm to make a short shift in the L.
The long road ahead
Ben
Post by Ben » Sun Oct 26, 2008 10:29 am
I had one in my first RX that I made, needs to 'adjust' the forward section of the shifter hole in the trans tunnel, and bend the shifter rod backwards a bit but worked sweet. About 50mm movement to change gears...
If you can't do it yourself find a shifter and post it to me and I'll do it for $20.
Please watch before posting!
T'subaru
Post by T'subaru » Mon Nov 03, 2008 3:02 am
I'm not impressed with the throw on my rx, stiff also. More info on this would be great. I dont have an accurate illustration for my linkage..still confused.
