motor recon places
- damosbrumby91
That spreadsheet is every dollar i've spent on the car. I've thought of one more thing to add to the list in post #17 above: make an engine stay rod (you might get by without one, but the engine will clunk around when off road). That should be it for my conversion (i.e. 1996 EJ18 into 1993 carbie 5 speed L series).
If you're keen you can do more things like making the radiator out of the donor car fit, adding a fuel surge tank and changing the gearbox at the same time. Some people also make up little wedges to sit between the engine mounts and crossmember, but that didn't look necessary for my car.
From memory the EJ18 was slightly narrower (rocker cover to rocker cover) than the EA82, but slightly longer front to back. So in the L series there is heaps of room around an EJ18. Your Brumby might be a bit different - I seem to recall hearing that the chassis rails are closer together. Talk to Matatak, Cam or Subarino about that.
I'll get exact measurements of the EJ18 in the morning.
And to get even further from the original topic: if you are the Damian I think you are, we have 5 friends in common on facebook. Small world eh?
Dane.
Dane.
- damosbrumby91
hey if it's Easyer email it to me on damianclaffey@iinet.net.au
- damosbrumby91
