Post
by steptoe » Thu Feb 05, 2009 9:23 am
you have not said you have removed the M6 1.0 with 10mm head from the back of the block holding the camshaft in place with the lock tabs and acces is through the holes in the cam sprocket. Did you see the 14mm sized head of bolt, not head bolt, that is found deep in one side of block in the middle, centre sort of thing?
whatcha got planned ?
