manual?
don't I need to ground some diagnose pin before I do thid procedure?
all the articles I've read say that the "Oil Temp" light should flash...
also... the Oil Temp flashes only once when I swithc IGN on... shouldn't it flash constantly if there were some faults dedected?
I managed to find a wiring diagram and pinouts.... compared all pins with given voltages on the pinout chart and everythins seemed fine except three pins - did not get any AC reading on the SPD sensor 1, selenoids 1 & 2 show constant 12V in all stick positions (they do change when I drive the car and when it shifts through the gears... not sure if the car should be stationary or driven when measuring the V output)... all other pins seem to give all the right voltages! not really sure what to thing of this since the "Oil Temp" light does not flash to indicate any detected faults...
maybe my trans is just dead...
