Biography of an EA82T Cylinder Head
nncoolg
Post by nncoolg » Wed Jan 06, 2010 8:19 pm
After looking into the Vortex Hi-Rise intake (would love to cut one of those up too) I Decided to cut a set of Gen2 heads 'in half' to get a clue as to where the weak parts were and where they can be improved, port flow wise...here are the photos:
They really do have quite extensive cooling around the IN ports, if only the EXH/IN ports were seperated like these:
(This photo also shows the area behind where the 'triangle' shaped water jacket in the block meets the head, they can be drilled here and allow coolant flow directly into the head)
Really not much cooling down the bottom end of these heads at all, water jackets don't extend past the siamese exhaust merge:
This one shows the bulge where the 'D' section meets the 'O' section:
# EA82 AWD 4EAT,
nncoolg
cont...
Again... Outlet bulges:
IMO the intake ports are quite good (also above), exception of course is the castings for HLA buckets protruding inside
I like this cut - it shows the very awkwardly shaped EXH port, the very long valve guide, and the amount of meat that is cast around the HLA buckets:
You can see how undercut the seat is in places, also shows bridge crack:
These ones also show the shape of the EXH port and quite a bit of material that could be cut out around the guide, which in my opinion could also be shortened:
# EA82 AWD 4EAT,
nncoolg
Post by nncoolg » Wed Jan 06, 2010 8:30 pm
I suppose I should show you the finished port job after I welded the heads back together...
Just Kidding:lol:,done to a different set of heads:
Post by Gannon » Wed Jan 06, 2010 9:18 pm
A W E S O M E ! ! !
have you got more pics of the area under the valve bridge crack?
What was wring with the heads?
nncoolg
Post by nncoolg » Wed Jan 06, 2010 9:33 pm
Yeah, Im going to take somemore pics when camera is charged and I can get some sun inside the ports.
What was wrong with them : They had Bridge cracks.
# EA82 AWD 4EAT,
Post by Gannon » Wed Jan 06, 2010 9:42 pm
Was it just cracks, or were they leaking?
Post by AlpineRaven » Wed Jan 06, 2010 9:42 pm
Interesting..... were these heads no good or you just decided to cut them up?
Post by steptoe » Wed Jan 06, 2010 10:32 pm
They is no good now, other than well documented presentation. I have a set to go on my engine soon, got them checked out by head shop . They say they are OK, even though they have the exhaust port leaking into combustion chamber - crack between both valves. I sorta don't like relying on this condition too much myself, so it is all experimentation.
Nice pics and thanks fer goin to the effort to share Neville
twilightprotege
Post by twilightprotege » Thu Jan 07, 2010 9:06 pm
great pics! thanks for the effort...
i look forward to knowing more about the head problems. both sets of heads i've had have had a coolant leak coming out of the driver side, from the top front head stud coming out of the small bolt hole that goes in to it from the top (almost below the thermostat if you're looking at it on a complete engine.
discopotato03
Post by discopotato03 » Wed Jan 20, 2010 5:39 pm
I gave my engine builder a pair of cooked EA82T heads to cut up before he ported mine . I asked several times if he'd cut them up and he hadn't - I don't know why . If he had I'm sure he could have done a bit more on those HLA bosses .
Those "outlet bulges" were mostly removed on mine to improve exhaust flow .
Cheers A .
Sweating on that computer Neville , cheers A .
discopotato03
Post by discopotato03 » Sat Oct 16, 2010 7:35 pm
Personally I think its debatable if you can take a whole lot out of EA82 MPFI inlet ports and get good gains . There's nothing wrong with cleaning them up and if you can take a bit off the rocker pivot bulge that wouldn't hurt either . The fella who ported my heads didn't cut up the cooked ones I gave him and even though I showed him pics of sectioned and ported ER27 heads in the lifter bulge area he didn't do much with them . My best guess is that he knew from building that engine that it wasn't going to make huge power so didn't do anything iffy .
I think the largest gains were made in the exhaust ports where they have a step in the wrong direction a little way in from the headers flange .
I think if you were going to run the standard MPFI turbo manifolds really the restrictions are mainly in the standard header and to a lesser degree the L type inlet manifold . The runners in the Spider manifold aren't any larger inside but the curve radius's are more gentle . The plenum volume I think is larger on the spider version .
If you wanted to make something custom then its possibly best to start with the spiders base flanges because they mount the injectors correctly aimed at the back of the inlet valves .
Everything I've ever read said that the cracks between the valve seats are no issue unless they leak in between . At USMB people have said that these heads sometimes leak coolant from a crack further down in the exhaust port and you can sometimes hear coolant hiss when it drips into the header after shut down .
There's a really easy fix , its called go to Repco or other and buy a bottle of Cargo Metallic seal up and follow the directions on the bottle . Basically flush the cooling system of green blood and pour the shaken bottles contents in a top up with clean fresh water . Run around for a couple of days with it circulating and then re flush the system and use a suitable coolant like Tekalloy .
For me no more hiss or coolant loss and the quickest simplest cheapest crack fix yet . My friend Coxy has been spannering for nearly 40 years and put me onto this fix .
A .
nncoolg
Post by nncoolg » Tue Jul 03, 2012 9:19 pm
finally filled-in the post I had reserved for later :rolleyes:
# EA82 AWD 4EAT,
Post by Gannon » Tue Jul 03, 2012 9:55 pm
Lookin good Nev, is that your big mug I can see in that reflection?
Why so shiny? is there an advantage?
So when are these going on the tex? Will you be accompanying them with an intercooler?
nncoolg
Post by nncoolg » Tue Jul 03, 2012 9:58 pm
they've been in it since its been on the road, just been computer-lazy:D
They go good.
Working on an intercooler at the moment actually, heres a sneak peak:
Image Image
# EA82 AWD 4EAT,
