Oil leak from head gasket on EA82
Posted: Sat Feb 20, 2010 2:07 pm
by LindsayD
I've got an oil leak from the head gasket on an EA82. I've changed the gasket but it's still leaking.
Does anybodyhave any suggestionson what can be done next?
Posted: Sat Feb 20, 2010 2:31 pm
by TOONGA
are you sure it is leaking from the head gasket?
it sounds pretty terminal for that head if it is
check to make sure its not the rocker cover gasket
Posted: Sat Feb 20, 2010 2:36 pm
by someguy
The rocker cover gasket is pretty common to leak oil on EA82's and isn't anything you should be overly concerned about.
Mine does that every now and then too (mines only done around 120,000km)
Il replace it one day
Posted: Sun Feb 21, 2010 11:26 pm
Or the oil pump. The oil pump is good at leaking and making it look like the rear seal is the culprit - I think this is due to the air movement in the engine bay...
That is if you did the head gasket correctly - did you have the headgaskets shaved to make sure they are not buckled? I always used a rubber O ring in there and I'd often pull them out kinked. That oil guide is a pain in the arse, as is changing the head gaskets...
Cheer
Posted: Mon Feb 22, 2010 12:05 am
by LindsayD
Its definitely the head gasket that is leaking.
Its making me think there might be a slight buckle in the head. Both surfaces were spotless when I put the new gasket in but still coming from the bottom rear corner.
It doesn't seem to leak much oil however there is plenty of oil on the under side of the sump so it got me thinking whether it was coming from somewhere else.
If it is the oil pump where would the oil be leakng from?
Posted: Mon Feb 22, 2010 12:11 am
LindsayD wrote:If it is the oil pump where would the oil be leakng from?
Usually the oil pump seal. To do it you have to take the cam belts off, then 5 bolts that hold the pump in. Clean both surfaces, replace the funny shaped seal, add a bit of silicone to the mix and reinstall it to the motor. Done.
Painful but it might solve that problem... Better than doing another set of headgaskets before ruling this out.
Posted: Wed Feb 24, 2010 9:22 pm
by tony
El_Freddo wrote:Usually the oil pump seal. To do it you have to take the cam belts off, then 5 bolts that hold the pump in. Clean both surfaces, replace the funny shaped seal, add a bit of silicone to the mix and reinstall it to the motor. Done.
and the other round oil seal .
Posted: Wed Feb 24, 2010 9:23 pm
by tony
actually also check its not the crankshaft oil seal, if it goes it stuffs the timing belts as well.
