Replacing L series Gear Box Oil Seals
Posted: Wed Apr 28, 2010 8:05 am
Hey all,
The auto to manual transfer is going well. Turns out the auto had a 3.7 rear diff, same as manual, which made life very easy.
Quick question. Going to replace the oil seals on the manual L series 5 speed 4WD Gear Box. I can see the rear seal and that seems easy enough to lever out with a screwdriver and replace. However the front seal at the clutch plate spline is posing some issues. I understand it is hidden behind the metal plate held on with three bolts. How do i remove this plate? Do i need a puller tool, or should i forget about the front seal?
