Only about 5000 kays old, Came out of my brothers NA liberty, Looks like its gotten really hot or something, any ideas on how or why?
It also stuffed the snout on his gearbox too, but the pressure plate is still fine.
I agree as the pressure from the pressure plate would of caused it to break like that. Question is How would you get the standard bolts in the fly wheel to start.RSR 555 wrote:I'd say it made noises for some time and if it's only been in there for 5,000kms then I'd say it was not installed correctly.. to me without seeing it first hand, I'd say the friction disc was put in upside down.
I get the Same thing in my GX and it's non turbo. It's just the stock clutch as well.. but the clutch is fine.wrxer wrote:i got one for my wrx, wasnt from gripforce tho, is a lightened flywheel, 4 puck bronze plate, and heavy duty pressure plate. not long after install it slips in 3rd when the boost hits the 20psi mark. it is also unpredictable in the friction point and sometimes has 2 friction points?
it is coming out
