diff winding?or tailshaft? :S
Posted: Fri Aug 13, 2010 9:25 pm
by jokerjanet
i had my outback out in the mud last night and i got bogged so my mate pulled me out with his 4x4 and on the way home wen i got out on the road about 2 mins into the drive home i heard a weird noise from the rear of the car sounds like the diff winding or something like that could i have stuffed the diff from getting bogged and being pulled out?the noise is only there wen i back off the power like if i am in a gear and hit the accelerator it goes away but as soon as i back off it makes the noise can someone tell me wat it could be cheers.....
Posted: Sat Aug 14, 2010 12:53 am
by phillatdarwin
sounds like u got some rocks in the dices in the back wheels
Posted: Sat Aug 14, 2010 7:57 am
by AlpineRaven
have a look at the rims that there could be mud sitting there causing off balance, if not check the drive shaft as something might've wounded on it then tail shaft - if normal then there is something wrong... advise us..
Posted: Sat Aug 14, 2010 10:51 am
by RSR 555
Ummm.. hate to say this but I think that when you got bogged in the mud, the diff instantly became cold and has drawn moisture inside it via the breather cap :( I would get the car on a hoist (or all 4 wheels off the ground) and check it in drive. I also even if not the diff.. would change the oil to be safe :cool:
Posted: Sat Aug 14, 2010 12:10 pm
by jokerjanet
thanx guys will have a look cheers
Posted: Sat Aug 14, 2010 4:20 pm
by jokerjanet
hey guys i should have checked it out before i asked the question i feel like an idiot now i looked at it,all the problem was,was the heat shroud for the exhaust was bent and moulded around the tailshaft causing it to rub and make the weird winding/grind sound but all fixed now lol.....
Posted: Sat Aug 14, 2010 5:07 pm
by AlpineRaven
jokerjanet wrote:hey guys i should have checked it out before i asked the question i feel like an idiot now i looked at it,all the problem was,was the heat shroud for the exhaust was bent and moulded around the tailshaft causing it to rub and make the weird winding/grind sound but all fixed now lol.....
Thought so something like that would happen... lucky you looked at these areas.
Posted: Sat Aug 14, 2010 7:23 pm
by jokerjanet
yeh i no if i didn find this site i would have just taken it to a mechanic telling them the diff is winding and they would have charged me an arm and a leg and said they changed the diff but reallly just fixed the heat shield (2 second job)cheers guys
