Post
by RSR 555 » Wed Dec 08, 2010 3:00 pm
Looking for any info on a EJ25 Quadcam engine that is in a Gen3 Outback.. I know they weren't available in Aus.. so I'm hoping someone overseas has some info like specs and wiring diagram.
The only info I have is the engine code EJ254DXDBE and it's from a 2002 Subaru Lancaster (Outback)
Any advise and help would be much appreciated
Disclaimer: Not my website but
hyperlink here to Subaru workshop manuals
d_generate
Post
by d_generate » Wed Dec 08, 2010 5:04 pm
Best I can do for you mate
Manufacturer Subaru
Flat four cylinder motor
2.5L
Quad cam
USDM market
Here's the best I could do on the wiring diagram, hope it helps,
Post
by RSR 555 » Wed Dec 08, 2010 5:16 pm
Excellent Tom.. thanks for your useless insight
I do like your crayon drawing.. did you do that in kinddie
Post
by TOONGA » Wed Dec 08, 2010 5:19 pm
LOL it looks like he copied my brumbys wiring harness
d_generate
Post
by d_generate » Wed Dec 08, 2010 6:37 pm
Sorry, couldn't help myself
Post
by AndrewT » Wed Dec 08, 2010 8:38 pm
were they only not available here in Gen3?
I had one which came out of an Australian delivered Gen2 Outback.
Post
by RSR 555 » Wed Dec 08, 2010 10:36 pm
Yeah Andrew, the Gen2 EJ25 was a different animal.. I will take some pics of this one but from what I noticed when we looked at it, was the manifold was a different design and I think (not 100% sure) that the heads looked like AVCS type. It was definately a Gen3 model with the larger headlight design but I can't tell what year it is until I do some more checks. I'm sure from searching the net, that it's more than likely around 2002.
Jules found this but the pics are small..
http://carbonus.ru/detail/yok-2526000/d ... _bh9_ej254
Post
by guyph_01 » Thu Dec 09, 2010 2:09 am
Hummmm, one small thing i notice from those pics toonga found is the num of flywheel bolts, 8 instead of 6 on the ej22 right? Also does it have the 8 bolt bell instead of 4 bolt one?
Thinking of going on holidays on a little paradise island, Check out
http://www.dodolidays.com
Post
by RSR 555 » Thu Dec 09, 2010 2:35 am
Nope.. all EJs have 8 flywheel bolts
and yes it has the 8 bolt bellhousing.
olddog642
Post
by olddog642 » Thu Dec 09, 2010 2:38 am
MMmm I think that the one Jules found in russia is an 8th month 2001
Hylton
Post
by guyph_01 » Thu Dec 09, 2010 3:10 am
ok, I've posted on USMB and Subaruoutback.org, I'll forward any relevent stuff i get:)
Post
by TOONGA » Thu Dec 09, 2010 9:52 am
RSR 555 wrote:Yeah Andrew, the Gen2 EJ25 was a different animal.. I will take some pics of this one but from what I noticed when we looked at it, was the manifold was a different design and I think (not 100% sure) that the heads looked like AVCS type. It was definately a Gen3 model with the larger headlight design but I can't tell what year it is until I do some more checks. I'm sure from searching the net, that it's more than likely around 2002.
did you click on the picture if you do they will enlarge next to the small ones
seems the Lancaster and that engine type were shipped to countries with other than English ticked in the export box
Venom
Post
by Venom » Thu Dec 09, 2010 10:32 am
I thought EJ254D was the code for a standard EJ25 quad cam. If it went to non-english speaking countries then maybe they were just using left over motors in the Gen3, googling only brings up russian stuff... which seems suss.
Post
by TOONGA » Thu Dec 09, 2010 10:52 am
Post
by RSR 555 » Thu Dec 09, 2010 11:43 am
Thanks Mark
I shall check that out when my internet (at work) speed is not minutes/bits
Post
by RSR 555 » Thu Dec 09, 2010 11:47 am
TOONGA wrote:suss it may seem but Russia and its federated states got quite a few Subarus we didn't
an example being the Subaru Retna
That was my daily driver in Japan.. 1.6ltr of pure power
Post
by TOONGA » Thu Dec 09, 2010 1:02 pm
4 engines listed in that FSM: 2l sohc, 2.5l sohc, 3l 6cylinder sohc, 2l dohc.
no 2.5l dohc
a good reference material that I didn't have before
Post
by guyph_01 » Thu Dec 09, 2010 1:43 pm
No luck yet on USMB or Subaruoutback.org:(
Post
by TOONGA » Thu Dec 09, 2010 2:41 pm
well Ive just looked again and I got zip you may need to go here
http://techinfo.subaru.com/index.html
