Page 1 of 3
Info on EJ25 Quadcam wanted
Posted: Wed Dec 08, 2010 3:00 pm
by RSR 555
Looking for any info on a EJ25 Quadcam engine that is in a Gen3 Outback.. I know they weren't available in Aus.. so I'm hoping someone overseas has some info like specs and wiring diagram.
The only info I have is the engine code EJ254DXDBE and it's from a 2002 Subaru Lancaster (Outback)
Any advise and help would be much appreciated
Posted: Wed Dec 08, 2010 5:04 pm
by d_generate
Best I can do for you mate
Manufacturer Subaru
Flat four cylinder motor
2.5L
Quad cam
USDM market
Here's the best I could do on the wiring diagram, hope it helps,
Posted: Wed Dec 08, 2010 5:16 pm
by RSR 555
Excellent Tom.. thanks for your useless insight
I do like your crayon drawing.. did you do that in kinddie
Posted: Wed Dec 08, 2010 5:19 pm
by TOONGA
LOL it looks like he copied my brumbys wiring harness
Posted: Wed Dec 08, 2010 6:37 pm
by d_generate
Sorry, couldn't help myself
Posted: Wed Dec 08, 2010 8:38 pm
by AndrewT
were they only not available here in Gen3?
I had one which came out of an Australian delivered Gen2 Outback.
Posted: Wed Dec 08, 2010 10:36 pm
by RSR 555
Yeah Andrew, the Gen2 EJ25 was a different animal.. I will take some pics of this one but from what I noticed when we looked at it, was the manifold was a different design and I think (not 100% sure) that the heads looked like AVCS type. It was definately a Gen3 model with the larger headlight design but I can't tell what year it is until I do some more checks. I'm sure from searching the net, that it's more than likely around 2002.
Jules found this but the pics are small..
http://carbonus.ru/detail/yok-2526000/d ... _bh9_ej254
Posted: Thu Dec 09, 2010 2:09 am
by guyph_01
Hummmm, one small thing i notice from those pics toonga found is the num of flywheel bolts, 8 instead of 6 on the ej22 right? Also does it have the 8 bolt bell instead of 4 bolt one?
Posted: Thu Dec 09, 2010 2:35 am
by RSR 555
Nope.. all EJs have 8 flywheel bolts
and yes it has the 8 bolt bellhousing.
Posted: Thu Dec 09, 2010 2:38 am
by olddog642
MMmm I think that the one Jules found in russia is an 8th month 2001
Hylton
Posted: Thu Dec 09, 2010 3:10 am
by guyph_01
ok, I've posted on USMB and Subaruoutback.org, I'll forward any relevent stuff i get:)
Posted: Thu Dec 09, 2010 9:52 am
by TOONGA
RSR 555 wrote:Yeah Andrew, the Gen2 EJ25 was a different animal.. I will take some pics of this one but from what I noticed when we looked at it, was the manifold was a different design and I think (not 100% sure) that the heads looked like AVCS type. It was definately a Gen3 model with the larger headlight design but I can't tell what year it is until I do some more checks. I'm sure from searching the net, that it's more than likely around 2002.
did you click on the picture if you do they will enlarge next to the small ones
seems the Lancaster and that engine type were shipped to countries with other than English ticked in the export box
Posted: Thu Dec 09, 2010 10:32 am
by Venom
I thought EJ254D was the code for a standard EJ25 quad cam. If it went to non-english speaking countries then maybe they were just using left over motors in the Gen3, googling only brings up russian stuff... which seems suss.
Posted: Thu Dec 09, 2010 10:52 am
by TOONGA
Posted: Thu Dec 09, 2010 11:08 am
by T'subaru
This was sent to me by a usmb friend, he thinks this might be what you need Paul.
cheers, Mark
http://wordpress.suberdave.com/?dl_name ... 03_FSM.pdf
Posted: Thu Dec 09, 2010 11:43 am
by RSR 555
Thanks Mark
I shall check that out when my internet (at work) speed is not minutes/bits
Posted: Thu Dec 09, 2010 11:47 am
by RSR 555
TOONGA wrote:suss it may seem but Russia and its federated states got quite a few Subarus we didn't
an example being the Subaru Retna
That was my daily driver in Japan.. 1.6ltr of pure power
Posted: Thu Dec 09, 2010 1:02 pm
by TOONGA
4 engines listed in that FSM: 2l sohc, 2.5l sohc, 3l 6cylinder sohc, 2l dohc.
no 2.5l dohc
a good reference material that I didn't have before
Posted: Thu Dec 09, 2010 1:43 pm
by guyph_01
No luck yet on USMB or Subaruoutback.org:(
Posted: Thu Dec 09, 2010 2:41 pm
by TOONGA
well Ive just looked again and I got zip you may need to go here
http://techinfo.subaru.com/index.html
