Auto to manual 2wd questions
85wrx
Post by 85wrx » Mon Apr 03, 2006 10:32 pm
I am converting an auto MY coupe to manual. Is the gearbox cross member the same for both the auto and manual? Does the auto pedal box have the provisions for the clutch cable bracket or do I have to fit a complete manual pedal box?
Regards Darryl
BaronVonChickenPants
Re: Auto to manual 2wd questions
Post by BaronVonChickenPants » Mon Apr 03, 2006 11:15 pm
I'm pretty sure of my answers, can someone confirm either way.
Is the gearbox cross member the same for both the auto and manual? No
You need the full manual peddle box
tim_81coupe
Post by tim_81coupe » Mon Apr 03, 2006 11:43 pm
On the money there Baron.
The pedal box isn't that hard a swap, it's just 4 bolts (or nuts... I forget)
I'm pretty sure you'll need to change the gearbox / swaybar / radius rod mounting plates with the manual ones too. The manual ones have an extra little bracket with 2 studs to mount the gearbox crossmember further up, although this could be a 4wd manual only thing.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
