L series shifter bushings
Posted: Mon Aug 15, 2011 8:21 pm
by Gannon
I did a search, but only came up with MY stuff.
Before I finish shortening the shifter linkages to go in the RX (with Liberty dual range box) and decided to tighten up the bushes while Im at it.
For those that have done it, where did you get the bushes? I was thinking of dropping into the local auto parts store and have a rattle through his box of rubber bushes to find some matches.
If I succeed, I'll post up my results.
Posted: Tue Aug 16, 2011 12:02 am
by RSR 555
They are still available from Subaru. I'm 99% sure they use the same as the Impreza but Andy (frog) should be able to help out here?
Posted: Tue Aug 16, 2011 12:24 am
RSR 555 wrote:Andy (frog) should be able to help out here?
He would certainly be my first port of call for something like this!
Posted: Tue Aug 16, 2011 8:12 am
Genuine coz they are pairs of bushes inside bushes
633011330 bush g/s lvr is one part number of three ?
search and should find a pic in here
Uploaded with
ImageShack.us
Posted: Thu Aug 18, 2011 7:00 pm
by Gannon
Andy has got me part numbers for the bushes.
Ignore the shortening of my linkages
Join 1 has 2 x 633124170 and 2 x 633124180
Join 2 has the same as above
Join 3 has 2 x 633011330
Join 4 has 2 x 33146ga210
Here they are dismantled
Posted: Fri Aug 19, 2011 8:10 am
Those steel spacer tubes !, I either need a pair or their specs, Gannon can you supply me their specs please?
tripping up on those deck nails yet
Posted: Fri Aug 26, 2011 9:53 pm
by Gannon
Good thing this was bumped up, I got the bushes in the mail today. BIG thanks to Frog for getting me the parts.
I'll install the bushes tomorrow and take more pictures. I'll also get the calipers out and measure those tubes for you Jon
The deck nails are on my to-do list, I ripped a sock on one the other day
Posted: Sat Aug 27, 2011 3:47 am
BUMP - those measures will be appreciated , anyone got spares kicking around?
Posted: Sun Aug 28, 2011 11:13 am
by Gannon
Ok, the tube is 36mm long, 11mm outside diameter and 8mm inside diameter
I have another linkage kicking around somewhere, if I have spare tubes, would you like them?
Posted: Sun Aug 28, 2011 7:12 pm
by Gannon
Shortened, welded and painted, plus the new bushes.
All ready to bolt in next weekend.
