L series low range into AWD box
I have a 1999 Outback AWD box with Dual Range.
I beleive the low range of these boxes is quite unimpressive compaired to the L series boxes. (not low enough).
Well I've got 3 L series dual range gearboxes sitting here....how difficult is it to transfer the low range gears from one of these into the AWD Outback box? Is it even possible?
Thanks in advance,
a.
Thanks in advance,
a.
- Ben
Al, is it possible to fit an earlier 4 bolt box to the 8 bolt engines? Reason I ask is I have a 8 bolt engine and want to use a forester 5 speed eventually in it with L low range...jzk25 wrote:Not possible, 8 bolt gearboxes use a totally new input shaft and hi lo syncro arrangement. I think SubaExtreme were developing a replacement input and hi lo for the 8 bolts but don't know if it is on the market yet.
- Outback bloke
There is no need to go to a Forester box to get the 1.5 low range.
Doing the lower low swap is not simple but doable. Subaman and I did it
to his box on the weekend. I will do some pics and a how to when I do
mine in the next few days. You end up with a constant AWD dual range
with 1.5:1 low range. The one I am building is a 4.111 dual range AWD
with 1.5:1 reduction with lower first and second gears as well. It is
also going to be electrically operated so I don't have to dick around
with linkages and levers.
- BaronVonChickenPants
- Ben
If there is more than 4 bolts holding the engine and gearbox together its an 8 bolt engine
the old boxes had two studs on the engine at the bottom, and two bolts either side at the top (one being one of the two starter motor bolts) Its easy to see a heap more bolts if its the 8 bolt one.
If your car is MY99 then it has the 8 bolt box for sure.
bahaha....
This has revealed a fundamental flaw in my conversion plans.
My 1999 Outback AWD gearbox is an 8bolt gearbox.
My 1993 Aussie spec EJ20turbo Liberty motor is a 4bolt motor.
I was heaps happy when I got the Outback gearbox cause it had low range and AWD (two features I really want).
Looks like I might have to find myself a 4bolt AWD gearbox now but I don't like my chances of finding another one with low range. I wonder if it's possible to change the innards and put them into the casing from a 4bolt AWD gearbox???
- Outback bloke
Oh right that's good news. The engine is still up on the stand and admittedly I havn't actually lined the box up against the motor yet.
So I guess 4 out of the 8 bolt holes should line up.
Great stuff! bit of a weight off my mind. Now I just gotta make sure I don't nail the EJ20turbo too hard when i've got it in low range.
Interesting Brett......... All 4.111 1st & second gears are exactly the same ratio as the 3.9 AWD. None of the 4.444 boxes i have looked at, have had a different ratios to the 3.9 & 4.111 early Lib boxes....byb555 wrote: The one I am building is a 4.111 dual range AWD
Why no 4.444????? Its looking like the auto Crown might fit.........
Time for a dummy fit up....
- Outback bloke
- Ben
I have an 8 bolt motor hanging off a L series low range box, the input shaft centres are identical between motors in relation to the bottom studs since 1972AndrewT wrote:Oh right that's good news. The engine is still up on the stand and admittedly I havn't actually lined the box up against the motor yet.
