What should I be doing for 100K Outback Service?
Posted: Wed Jun 27, 2012 9:59 am
by gjws
Hi all,
I'm looking to do the 100K service on my 2004 3 litre Outback. I've ordered the NGK platinum plugs from the USA ($97 for 6 delivered, as opposed to $24 each locally!) and I'll obviously also do the oil and oil filter, but what else should I be doing?
Fuel filter? Air Filter? Transmission fluid? Power Steering fluid? All of the above, none of the above? What else?
Thanks in advance for your help.
Posted: Wed Jun 27, 2012 11:10 am
by Alex
100k is the big service.
your car is a 6cylinder so you have a timing chain (which should last the life of the vehicle)
100k service involves replacing every fluid in the car. Even the rear diff. This is why subaru will charge well over $1000 for the service.
Posted: Wed Jun 27, 2012 12:06 pm
by Gannon
Yeah get in contact with forum member 'FROG' who sells genuine Subaru parts. He'll get you all the filters needed for your service.
Posted: Sat Jun 30, 2012 8:02 am
by gjws
Thanks guys.
Just want to see I have everything covered:
Engine oil
Transmission fluid
Power steering fluid
Brake fluid
Diff oil
Anything I've missed? Should I flush the radiator fluid?
Posted: Sat Jun 30, 2012 8:26 am
by Gannon
Yes you should flush the radiator, but I wouldnt worry about the power steering.
Posted: Sat Jun 30, 2012 8:32 am
by Alex
Yes.
You should be doing engine oil, transmission fluid, diff oil, brake fluid, coolant, oil filter, transmission filter, air filter, fuel filter, spark plugs. Anything that's replaceable basically gets done at 100k.
100k and 200k are the major service intervals for the car apart from the normal minor services in between
