Who'll pioneer a blower in a Brumby?
Posted: Sat Jun 30, 2012 10:55 am
Supoercharger in a brumby?
If I had a brumby I'd certainly do it. Absolutely.
But I have a new Jumbuck and havent a need for a brumby. Pity. Just that after my latest ride on the supercharged Tweety trike I would make hell or high water to put the same set up in a brumby if I had one. Think of the benefits.
- retain the same or even less compression ratio. So a slightly worn engine would still be ok.
- No need for twin carbs, twin carb manifold, linkages (and obtaining them)
- no carbie balancing issues
- No EJ conversions and the issues that come with them (body, loom, space, complexity- mind you there are many positives)
- Not much more fuel usage
- No cam or internal changes if boost is mediocre
- Cost effecitve. (debatable but considering the alternatives of modifying the ea81 in the traditional sense.
- cool factor
- Sc can be operated in reverse
- and add a cool badge. lol
Cost around $1500 max. Power- incredible at 6-8psi, torque neck snapping throughout the rev range, simple, no electronics and one extra ribbed belt.
Ok, you guys are saying...what about the loaction issue. where is it going to go? Firstly where there's a will there's a way...my stategy since converting Tweety to Subie power last year not to mention the roof creation.
What about a shaft mounted above the left head to the rear of the engine and the SC12 or Sc14 mounted central above the flywheel area and utilise the spare wheel area for the carbie. Remember the carbie doesnt have to be moutned directly to the SC. It can be remote with a tube connecting it. We are talking draw through. Furthermore the Sc can be run in either direction so it could be reversed if you want the carbie to extend across the drivers side. It can also be laid down reducing its height. Actually I'm amazed at the virsatility of the idea. Find space for it and a way of powering it and you have your 30% extra power.
And a small bonnet scoop isnt out of the quesiton. Anyone wanting to pioneer the concept has Joels thread and now my tweety thread as a good guide. Just need Subie Brumby die hards out there to work through the space issue.
Your thoughts?
- cool factor
Your thoughts?
