EA81 head studs and torque settings.
- Brumby Kid
I have always thought that ea81's had 14 studs. 7 in each head. However after getting my engine back I found 9 threads in each head. I'm unaware whether these were heli coiled when the engine was being built or not.
Then I found a sheet that tells me in which order to torque the nuts. It says there are 9. How many are there ment to be? I had 4 across the top and 3 across the bottom when I took it out.
They are below and either side of the bottom middle stud.
Also I believe there are two holes for a small plug that fits half into the block and half into the head. Are there meant to be two plugs?
If anyone has any torque settings with degree measurements laying around I would love them. For all of the engine.
Cheers Cam
Cheers Cam
- Silverbullet
This is the case, the two bolts for the rocker gear are part of the torque sequence. But as I found out at the wrong time you will need a special tool (jonno has the picture) or make your own out of a cheap socket for those two bolts. Because the head of the bolt is half under the rocker shaft you can't get a normal socket over it. I got a cheap 17mm socket and ground a big step in it leaving the a complete ring at the bottom for the bolt head and the big hole gave me just enough movement to give the bolt about 1/50th of a turn before I had to reposition itTOONGA wrote:you will find there are seven studs and two bolts for the rocker gear.
I have the 1983 fsm if you want it and the gregorys manual is here
- Silverbullet
Torque for crankcase nuts and bolts:
M10(x6): 39-47Nm/ 29-35ft-lb
M8(x2): 26-26Nm/ 17-20ft-lb
M6(x2): 4.4-5.4Nm/ 3.3-4Ft-lb
Torque for Crankcase plugs:
62-76Nm/ 46-56ft-lb
Torque for oil strainer stay:
23-26Nm/ 17-20ft-lb
Torque for cylinder heads
1st step: 29Nm/22ft-lb
2nd step: 59Nm/43ft-lb
3rd step(final): 64Nm/47ft-lb
Torque for flywheel housing:
20-27Nm/ 14-20ft-lb
Torque for oil pan bolts:
4.4-5,4Nm/ 3.3-4ft-lb
Torque for flywheel bolts:
49-53Nm/ 36-39ft-lb
Torque for clutch cover:
16Nm/ 12ft-lb
Torque for crankshaft pulley:
64-74Nm/ 47-54ft-lb
Torque for intake manifold bolts:
18-22Nm/ 13-16ft-lb
62-76Nm/ 46-56ft-lb
23-26Nm/ 17-20ft-lb
20-27Nm/ 14-20ft-lb
49-53Nm/ 36-39ft-lb
16Nm/ 12ft-lb
64-74Nm/ 47-54ft-lb
18-22Nm/ 13-16ft-lb
Those plugs you mentioned that has no answer yet are two dowels to help align head and it makes sense you have two per head, sometimes if one sticks in block the other might stick in head, then, you get left and right mixed up and find one in head mates against one in block.
My home made tool was for EA82. I used a bent spanner for EA81, resembles an open end ring spanner with the open end should be 17mm , but it was an imperial size
the end that is normally ring was actually square for 1/2" inch drive torque wrench. Factory bent into a U shape.
I'm still waiting for you to ask the torque rating for installing the studs into the block !
There is a cool tool packaged in Stanley brand stuff at a few auto parts joints called a stud remover..prety handy here
- Brumby Kid
Thanks guys.
Yeah I have a cheap stud remover, it abbliterated the old ones.
We are doing them up carefully with that with gasket goo.
Has anyone got any pics of this magical tool and what it's used for? I thought you did the rocker cover bolts on outside the rocker cover.
Thanks Sam, do you have the degrees? Like 40nm turn 90deg and then 50nm?
Cheers Cam
Cheers Cam
Usually the headgasket comes with torquing instructions.
- Brumby Kid
Sweet that's great, I don't have the tool for yielding degrees.
The head gasket did come with torque settings but I don't trust them.
I'm going to use the Subaru specs.
Cheers Cam
Cheers Cam
- Silverbullet
Different bolts we're talking about. The big long ones that hold the rocker arm assembly onto the head are the 2 extra threaded holes in the block. Two little ones that hold the rocker cover on are unrelated. Dunno what degrees has to do with it, never heard of it before!Brumby Kid wrote: I thought you did the rocker cover bolts on outside the rocker cover.
Cheers Cam
Jonno, cylinder head studs into block torque is:
34-44Nm/ 25-33ft-lb
My book literally has everything, even info specific to twin carb models
