Brumby Story
Posted: Sat Jan 05, 2013 7:09 pm
Hi guys - My Brumby - 88 Ag Quip - 380,000kms - original engine - When I bought it ($300) I had the heads off because of suspected failed gasket (was a welch plug) and I wanted to have a look anyway - the bottom waterways were clogged - anyway it never ran quite the way I thought it should - idle problems (carby to bits lots of times) - never started first go when hot, always second time - would suddenly run a whole lot better for a few seconds, and this went on for about 20,000kms - just recently it began to refuse to start when hot (with no fuel pump operation) and would start when cool - thanks to this forum I suspected the distributor and fuel pump relay - Ive got a few sportswagen wrecks but had given away all of the distributors - Doh! - In desperation I looked through a box of bits in one of the wrecks and lo and behold - an ea81 points disributor !! - a fuel pump relay from an L series - and now it idles - starts first go - has more power - fuel pump primes as it should - and probably better economy !!
