Drive shaft lenghts
Drive shaft lenghts
what is the difference in length between an L and my front driveshafts? I am having problems with my brumby breaking/pulling apart the DOJ on the diff end of the shaft. This started when I fitted slightly longer adjustable caster rods. I have also moved the control arm mounting hole out 12mm to fix a camber problem. It has a 50mm lift kit with standard springs fitted(not HD). I had L control arms on my last MY and used L driveshafts with a long travel front strut and had no problems. I dont wish to do the same with this vechile.
the shaft itself minus joints on both ends is 45 mm longer in the DL L series 5 speed manual wagon I hads bits from compared to my Brumby.
. the diameter of the shaft was less than my Brumby bits for comparison.
the stub axles are different in that the L is wider between where each bearing sits, the spline is shorter for the hub. overall length is same as MY
I wrote this stuff in my manual so is not off top of me head!!
