Looking at my EA82T for removal, things are a bit different than normally aspirated, namely the hairdyer and associated plumbings .
What do you have to undo and / or remove before lifting motor out or just remove heads. Take fuel lines and cables etc as a given thing.
Do you take the back door approach and remove exhaust from turbo first, then turbo oil line in and out , then water then stay bracket, then crossover pipe..
Does crossover pipe come off before lifting engine ?? Or is it stuck there ?
OR
If I choose to do heads in car ( even though I have said it is easier to work on out of car) because of the auto , lines and bloody messy tranny fluid, do you just remove exhaust studs and timing belts etc of course.
EA82T - engine removal - tips wanted
- tim_81coupe
