L Series RX clutch V's non turbo clutch
Post by steptoe » Mon May 22, 2006 11:08 pm
We now know the pedal box in RXs are different to non turbo EA82 L Series pedal boxes. Were the clutches heavier from factory ?
Some have already said the Daikin or RPM clutch kit number 397 is satisfactory in both (I think ?)
The turbo clutch cable has a heat shield
Other known differences ?
Chris_Rogers
Post by Chris_Rogers » Thu May 25, 2006 12:00 pm
daikin is waht I had in my old one. works well and its still the weakest part of the driveline so it wont destroy boxes . theres a difference is size between 2 & 4wd. unsure about the rx vs 4wd though.
do you still need that shifter assy? (pm me.)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
PeeJay
Post by PeeJay » Thu May 25, 2006 9:52 pm
From what I can gather the 4wd and RX clutch are the same. Even the wrx uses the same disk as an RX, just a different pressure plate and flywheel.
tim_81coupe
Post by tim_81coupe » Thu May 25, 2006 10:20 pm
Give me a couple of weeks to find out the hard way, but I am sure the EJ clutch is a larger diameter with beefier splines on the input shaft. I'm pulling out my EA82 some time soon and replacing it with my EJ20G, so I'll have them side by side at one point...
Isn't the EA82 clutch 225mm and the EJ20G one 230mm?
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Subaman
Post by Subaman » Thu May 25, 2006 10:24 pm
The EJ clutch plate is exactly the same diameter and has the same splines as the L Series, even the EJ20T is the same size.
