5 speed diff ratio
Posted: Wed Dec 04, 2013 8:47 pm
by badga880
Once again I need some guidance I have a good 5 speed G/box that came out of a car in japan which had a turbo EA81 some sort of Leone type my question is how do I work out the diff ratio as I want to fit it in to my 92 brumby once again thanks
Posted: Wed Dec 04, 2013 9:25 pm
by TOONGA
If it still has the code on the side of the bell housing you should be able to find out via that, if not you need to drain the box. then mark one of the teeth on the crown wheel (white out or a paint pen) through the drain hole. then slowly rotate the the front output shaft and count the teeth untill you are back at the mark 37 teeth = 3.7, 39 teeth = 3.9.
Posted: Wed Dec 04, 2013 9:35 pm
by tambox
If it is the original turbo box it will be a 3.7
Being an MY the teeth are 37 = 3.7 37/10
35 = 3.9 35/9
Posted: Wed Dec 04, 2013 9:38 pm
by RSR 555
Have you got any pictures of the box? as the EA81 Turbo came out with the 4 speed. I think it may be the EA82 Turbo box, as these were 5 speed. Most likely it's a 3.7 but as TOONGA has mentioned, if you can tell us the transmission number on the front bell housing, then we should be able to work it out.
Posted: Thu Dec 05, 2013 5:32 am
by badga880
Thanks I will get the numbers of the bell housing and post it once again thanks will not be able to get to post the numbers till later in the week but will be back thanks
Posted: Tue Dec 10, 2013 11:59 am
by RSR 555
Any luck with the number?
Posted: Tue Dec 17, 2013 9:18 pm
by ozbrumby
RSR 555 wrote:Any luck with the number?
Paul
From past experience these numbers can be hard to decipher.
Just ask me
Look at the dramas I have had finding an AWD box
Thanx to you and Niterida my problem will be solved shortly
Appreciate the help guy
Peter
Posted: Fri Dec 20, 2013 1:07 am
by RSR 555
Numbers are the first place I look at but sometimes they don't turn out so good but need to start somewhere.
No worries on helping you out Peter
Posted: Sun Dec 22, 2013 8:46 pm
by ozbrumby
Huge appreciation to you mate
thanx heaps
and to Ken as well as he looked after me with price
Two good guys folks
Peter
RSR 555 wrote:Numbers are the first place I look at but sometimes they don't turn out so good but need to start somewhere.
Posted: Sat Dec 28, 2013 12:49 pm
by RSR 555
ozbrumby wrote:Huge appreciation to you mate
thanx heaps
Two good guys folks
Peter
No worries at all Peter. Hope you get it sorted
badga880 wrote:Thanks I will get the numbers of the bell housing and post it once again thanks will not be able to get to post the numbers till later in the week but will be back thanks
Any luck?
Posted: Wed Jan 01, 2014 9:51 am
by badga880
Sorry everyone been away numbers on this gearbox was a little sticker with,,930824 this sticker was up n the bellhousing also stamped in the box was 649 and hand written in pink paint pen was 649 as well hope these numbers will help someone be able to work out what gearbox this could possibly be thanks again and sorry I have been away
Posted: Wed Jan 01, 2014 11:41 am
by RSR 555
No worries badga880 but this 930... number is just the batch built number and the pink written one is more than likely a secondhand parts place stock number. The number we need should start with TY7...... and be about 10 digits long.
You can do as prevously mentioned, count the front crown wheel teeth. This can be done really easily.
Is the box in or out of the car? Can you post pictures of it?
Posted: Thu Jan 02, 2014 5:39 am
by badga880
numbers a little sticker on the bell housing about 1 inch long with numbers 930824 also 649 stamped on gearbox where 2 sections bolt together (highly technical) these are the only numbers I could find once again thanks I am aiming to get a pic of the box as sson as I can wok out how to get it off m phone to the computer
Posted: Thu Jan 02, 2014 10:09 am
by RSR 555
No worries. The TY7... numbers would be close to where the starter motor bolts on and down the side a bit but if they eren't there, then the sticker has fallen off. Best way then is to count the crownwheel.
Posted: Thu Jan 02, 2014 10:18 am
by badga880
Box out of car was going to fit it when I fit reco ea 81 that I have on the bench will try these photos today when the grandson drops over. Ok old farts are slow on these computers lol thanks for all the help
